MattyCiii said:There's a lot that can go wrong with this type of mix and match. See my A-Line build thread. Here are some lessons I learned from my experience:
- The tire, inflated, won't likely be the specified width. This is because width varies with rim width. As a result my wheels barely fit my bike, I have maybe 3mm clearance on one side and 4mm on the other (need to center that wheel...)
- With spokes, thicker does not always mean better. Spokes work through tension. A thicker spoke needs more tension to do its job, and if your spoke is too thick you'll pull the flange right off the hub before you reach the appropriate tension. With this in mind:
- I bought 13ga spokes - a good middle between the moto rims and bicycle hub.
- I got these with oversized nipples... But even then, the nipple heads pass right through the moto rim spoke holes. Solution? I put washers on the nipples so now they don't fall through. This arrangement is holding up fine through wheel build, tensioning and truing - but I have not ridden the bike yet so I have no ruggedness test.
- I bought a tubeless tire, but as a spoked rim I decided not to try this setup as a tubeless wheel. That means I get the worst of both worlds:
- The tire was a SOB to mount. I had a motorcycle shop do it and they struggled.
- It's heavier than it has to be, with the tubeless construction and added weight of the tube.
- I get none of the advantages of tubeless
ian.mich said:Ok so you're saying:
get a motorcycle wheel and tire, run the tire tubeless if I can, get 13ga spokes and nipples, and what size are the washers and where do I put them on the nipple?
And I still havent had my question answered, where can I get a rim and i guess a tire too at this point?
Thanks so much for your help
That's the hard work, and it's so specific to your frame & your vision of the desired outcome that it's inherently a job you must do. I googled around for days to get the wheel/tire combo I bought, and even then there were revisions, risks and compromises.ian.mich said:And I still havent had my question answered, where can I get a rim and i guess a tire too at this point?
That info is more a metaphor for what to expect in your planning process. But here's more related info. I had to get spokes custom cut. I went to Holmes Hobbies. Notice "13ga large: 4.77 body 7.75mm head (special order)". I noticed #10 washers would fit my need: ~5.5mm ID is larger than nipple body and smaller than head: GOOD. It's OD is 12.7mm, which is larger than the ~10mm spoke holes in the rim: GOOD. Placement isn't tricky, just use the washers on the spoke nipple just like a washer used with a lag bolt. I used two washers because they're thin.ian.mich said:...13ga spokes and nipples, and what size are the washers and where do I put them on the nipple?
ian.mich said:I was wondering where I could buy a 24in motorcycle rim for my GM/conhis/yescomusa etc hub motor (36 hole)
I have contacted about 5 manufacturers asking for that size and hole count but they seem to just ignore me :S
ian.mich said:Nah I was looking at 26in bike tires on a 24 in rim (my frame takes 26in tires, could be tubeless motorcycle tires for all I care), but i guess ill go to 22in rims to have some clearance
ian.mich said:Oh I was just wondering about the motorcycle rim as it seemed that was the best option due to strength, i guess its back to dual wall rim searching for me. also, ive been looking for hub motor spokes, i should get custom 13g spokes using the spoke calculator no?
rkosiorek said:if you are going for motorcycle tires on motorcycle rims, I'd say pass on the 16"moto rim. go for either a 14" or 17" moto rim. you have a lot more tires to choose from. 16's seem to be an unpopular size these days.
you can get some very heavy duty double wall bicycle rims for 26" tires, they'd be a lot lighter, cheaper and easier to fit than the moto rims.
wesnewell said:I was looking for the DHL42 some time back and couldn't find them.Well, last I checked they were available (in 12ga drilling only) and only about $35 retail. I picked up a pair for the shop. They seem to be excellent rims for the price. 12ga drilling makes sense for 14ga spokes on hub motors, because it allows a larger range of spoke exit angles than normal 14ga drilling. You have to use close-fitting washers to support the nipple heads, though.
FWIW, a 26" bike rim is 22.5" diameter.
Chalo said:Here's a super strong, very inexpensive 26" bike rim that weighs a bit over 800g. My shop sells this rim for $36 retail. If you need more rim than this, you must weigh 500 pounds, or you're doing something terribly wrong with it. http://www.weinmanntek.com/Products/CHOPPER/DHL42.htm
Dan's Competition has 14/15ga butted Belgian stainless spokes for $0.40 each.
ha nice. I too have settled the two DH39s from amazon. I actually unlaced both rims, relaced one in my motor with 12g holmes hobbies spokes in 1x. For the front the hub got replaced with a shimano disc hub, and reused the spokes. Tires are 2.1 schwalbe smart sam with a STOP FLATS liner, panaracer DH tube, and 2 rim strips (per wheel). The whole setup is going to last for long time and never pinch flat.wesnewell said:I was looking for the DHL42 some time back and couldn't find them. Ended up buying 2 DH39 front wheels and taking the rim off one to use with my hub motor. 1000W yescomusa hub motor laced into it nice using 165mm 12g stainless spokes in a 1X pattern. Perfect for 1.95 and larger tires. FWIW, a 26" bike rim is 22.5" diameter.
