Kepler
After putting together a 100V hub motor setup on my Merida TFS500 Hard Tail Mountain bike, I figured it was time for a new project and an entirely new direction. I really enjoyed the high power hub motor setup but felt my good quality super light 10kg bike was wasted on this setup and really missed just riding it as a normal bike (except up hills). My 100V hub motor gear is going into a cheap dual suspension platform but that’s a story for another day.
So my main criteria were for the new system to have as little impact on the standard bike as possible. It would be used primarily as a hill assist with the bike ridden as a normal bike most of the time. Target checklist is as follows.
=> 2 Kg in weight including battery
=> No drag at all on the bike when throttled off
=> Very quick release and re fit (30 second target)
=> 6S LiPo configuration to utilize cheap low Voltage speed controllers
=> 1000 Watt max output
=> 40 kph top speed
=> Very compact configuration
From the title of the thread, this obviously is a friction drive setup. However this is a friction drive with a difference taking in all the best documented design ideas but adding a few new tricks which makes this setup a little unique.
The prototype is built and under test at the moment with the results very encouraging so far. Stay tuned. Photos and design details to come.
=> 40 kph top speed
