adrian_sm
_________________________________________________________________________________________________________
[EDIT #2] 23-May-20011
New website, that tries to summarise everything from here.
http://sites.google.com/site/commuterbooster/
[EDIT #1]
For those new to the thread, there is a now index in the next post that might help you navigate
Now back to the original first post....
I have been ebiking for more than a year now as my primary means of transport. Commuting to work every day, and loving it.
Originally I had a crystalyte 408 on a hard-tail mountain bike, that weighed in at ~ 29kgs. At 48V I was seeing about 700W, and flat road speed of ~40kph. This was a nice set-up which I would recommend to others. Then I went to a full suspension bike, as the hardtail was getting a pounding due to the extra weight. I also upped the volts to 72V @ 30 Amps, giving me 2kw peak, and flat road speed of ~50kph. These speeds and power levels are more than enough for the commuting type ride, in rolling hills that I do around Melbourne. But I still felt like the bike was a big heavy beast. Due to the weight of the hub motor, and batteries you have to build it on a strong bike, with good wheels, and fatter tyres. IMHO.
So this got me thinking about how to achieve a light weight system, aimed at your commuting type rider. I loved Kepler's drive but want to do things slightly differently. To try and make it more compact, less visually obvious, less parts, and hopefully cheaper to manufacture.
This is what I came up with on CAD. I call it the "Commuter Booster"
It is mounts at the top of the seat tube, below the seat stays, and should weigh in at less than 1kg, excluding batteries.
The clamp is a modified OEM.
The motor is a $40 - Turnigy AerodriveXp 90 SK Series 50-65 270Kv
The controller I plan to try is a $37 - Turnigy Brushless ESC 85A w/ 5A SBEC
Batteries will be $50 - Turnigy 5000mAh 6S 20C Lipo Pack
There are three main custom parts, which are green in the above image, the main pivot block, and the two pivot arms.
Before making these properly, I mocked them up from wood, and here are some images of how they turned out.
Next steps:
- finalise dampening, springs and dead stop adjustment
- make the pivot block and arms properly from acetal, and aluminium
- resolve throttle type and placement (may be just a 3 position switch, and ramp control)
Oh and I found a frame mounted bag that is just large enough for two 6s 5000mah batteries. Here's a pic....
- Adrian
[EDIT #1]
Next steps:
- Adrian
