oatnet
The steering on my x5tracycle has always been twitchy, and I have attributed that to the rake of the front forks. The xtracycle lifts the back end of the S-750 frame higher than it sits natively, so the forks are more toward vertical instead of leaning back. I'd like to replace them with something taller to get more rake out of it, but I want to do it as cheaply as makes sense.
With the old Kelly Controller this did 44mph, and the forks are the suspension for the whole bike, so they need to be strong, but this is a commuter not a downhill racer, so I don't need something esoteric. I need something wide enough to accomodate 2.5" maxxis hookworms, and a disk brake mount, and frankly the taller the better.
So I could use a primer on bike fork heights, if anyone has the time. Are triple crown forks the same height as regular forks? Are all forks the same height, or what can I look for to find a taller fork?
Thanks!
-JD
Thanks!
-JD
