CogHog
If you haven't ridden one you don't know how bad they turn at any speed. I used a .75" diameter steel pin to pivot on my buddies bike. The rake is too much as I put the 20" tires on the back for stability so the front tire turns using the side of the tire. Need a bigger rim, smaller tire, better seat, and better handle bars. Needs more work but for the most part rides like a regular bike in straight line.
http://youtu.be/l6ZV9tsTENY
