whereswally606
http://endless-sphere.com/forums/viewtopic.php?f=6&t=34230&start=225
after seeing this thread above and gawking long enough at the excellent builds Oatnet puts together time after time I decided to give the fork mounted battery ago for myself. having not a lot of money I think I have managed to do my mount for very little moola only time will tell how wise this will be in the long run.
my mounts consist of 4 triple clamp scooter clamps from ebay which came in at about £14 delivered, some alu angle iron which was about £5, 12x m5 10mm flat head bolts £3 (B&Q)
4x m6 bolts with nordlock nuts (had them lying about) and an old ikea chopping board (also lying about)
sum total = £22
The rationale behind the chopping board was to make it easy to adapt the mount to when I upgrade the battery, I plan to do a pelicase lipo battery with a fetcher 4.4 zephyr bms (got the parts just need the time) currently the battery is very easy to remove which It wasn't when I had it mounted upright behind the seat post.
The battery is a Golden motor limn and it weighs about 5kg so getting the weight central was really important. anyway here are some pictures to go with my thousand words.
Checking Centre of Gravity
Bare mount no Steel bracket
sum total = £22
