fechter said:
Also got the MMG moped tire mounted on the rear. It went on easier than the front one, maybe just due to experience.
This is a pretty old post to reply to, but:
I am looking at using this same MMG 16x2.75" tire
https://www.amazon.com/gp/product/B00QMJV9VM
on almost exactly the same wheel (one i built using a stromer ultramotor and ypedal ex-zero rim) on the SB Cruiser trike, since my Shinko SR714 16x2.25"
https://www.amazon.com/gp/product/B00274F0G6
on one side is very worn and should be replaced soon, and if I do one side I might as well do both with bigger tires if they'll fit my frame...and that's the question:
If you happen to know, what are the actual tire measurements, on that rim, inflated? Meaning, how "high" does it stick up from the rim edge, and how "wide" is it from outer sidewall to outer sidewall at the widest point?
If you don't know, I can guesstimate by counting pixels vs the known rim size (or other things) in the pic, but an actual measurement would be safer.
I was also considering a similar MMG tire but with a smoother tread pattern as I don't need the traction pattern on the other one; I would guess it would come out close enough to the same size:
https://www.amazon.com/gp/product/B00V6KW2IQ
This is the wheel in question on SB Cruiser with the Shinko on it; the one on the other side (which you can't see) is an MXUS450x (would actually like to try another Ultramotor on that side if I can find one cheap) but it's the same rim:
