Andre´s STRAIGHTLINER RISING SUN
Rovi
1 W
1 W
Post by Rovi » Jan 20, 2016 8:59 am
Hi everybody,
hope to be right here to present my own created bike.
This is my first and last bike I designed to have fun.
It will be a hybride (manually and electrically usable.
The first thinking was to take a manufactured bike (Ruff Porucho), cut the tubes and put some extension inside.
But after some cut´s we decided to build it completely new, only using the seat tube, bottom bracket housing and the drop out.
Lets say the manually bike is ready and I start now with the electrical part.
Using a Cromotor in 21" motor bycicle rim with 90/90 21" tyre.
Kelly Controller KHB 14401 (24-144V, 200/400A)
6x 6S LiPo battery pack 5Ah (at the moment.
I want to start with 50V 15Ah first. But a lot of things are to do. The complete project already started one year ago by designing the frame.
... but there is a lot to do at the moment!!!
Regards Andre
Designed via MS Paint :-)
First build up
Before destroying the frame
Bike 020a.jpg (153.3 KiB) Viewed 2772 times
Building new frame
Bike 046.JPG (136.02 KiB) Viewed 2772 times
Ready welded
Fertig 002_klein.jpg (141.63 KiB) Viewed 489 times
Manually version ready
Start now with the motor
Test 029_klein.jpg (197.26 KiB) Viewed 489 times
Box for electrical parts (Controller, main relay, fuses, batteries, cabeling)
Weihnachten 242_klein.jpg (197.78 KiB) Viewed 489 times
OCD
Re: Build up Straightliner Sunrise
Post by OCD » Jan 20, 2016 9:36 am
Lookin' good! I don't see a pivot for rear suspension, is the shock just for appearance? That's a brave thing to cut up such a nice frame. :mrgreen:
beast775
Post by beast775 » Jan 20, 2016 2:08 pm
Damn Slikk 8) ...
2 FINGER SALUTE TO ESSO.no buying gasoline for 7 years now.
I spent all my money on bicycles women and beer the rest i just wasted.
Rovi
1 W
1 W
Post by Rovi » Jan 20, 2016 2:34 pm
There is no rear suspension, it only stable the rear "swing arm" to the main frame and for optically design :-)
Rovi
1 W
1 W
Post by Rovi » Feb 26, 2016 6:58 am
Hi guys
How to kill a Kelly controller?
First test were awesome.
I started with 48V DC ... everything was ok but I do not like the top speed!
So I rise up to 96VDC ... much better top speed and normaly I should stop here but
no risk no fun!
So I increase the voltage to 144VDC
Enjoy the video:
https://youtu.be/JuyvykF4KZw
Everything in no load modus.
150A fuse blown away :-).
The cromotor seems to be ok!
The controller is back on the way to China :-(
During waiting time I can ride it manually:
https://youtu.be/u_sAWqWqgR8
Test 004_klein.jpg (219.73 KiB) Viewed 487 times
Test 042_klein.jpg (214.87 KiB) Viewed 2589 times
WoodlandHills
Post by WoodlandHills » Feb 26, 2016 6:57 pm
Can you show a picture of a person actually riding this? I am trying to imagine what shape human could actually pedal while seated for more than a moment or two. How far is it from the seat to the handlebars?
Rovi
1 W
1 W
Post by Rovi » Feb 26, 2016 11:37 pm
Sorry, I don't have a photo at the moment but a short clip from an earlier stage where I want to imagine the distance from seat position to the handle bars:
http://youtu.be/i80VAPQzcYA
The distance from the middle of the seat tube to the middle of the steering head is 99cm!
For me it's not a problem as you can see ... Long legs, short upper body and long arms ;-).
But to be ownest I ride the bike more relaxed with only one hand at the handle bar ... It's a selfmade cruiser :wink:
Rovi
1 W
1 W
Post by Rovi » May 27, 2016 6:29 am
Now it´s running at 75VDC :-)
It´s awesome and so quiet!
Later on I will increase the system voltage.
Kiste läuft 009.JPG (193.45 KiB) Viewed 2342 times
macribs
1 GW
1 GW
Post by macribs » May 28, 2016 3:49 pm
Nice looking but oh my it must be so uncomfortable to ride. And why did you design it with stump swing arm when you already got a rear shock?
Rovi
1 W
1 W
Post by Rovi » Jun 06, 2016 7:58 am
The rear shock is only for optical design and let's say I I is not uncomfortable to ride!
I want to ride it on 1/4 mile first time at the weekend.
Rovi
1 W
1 W
Post by Rovi » Jun 13, 2016 2:30 am
I run the bike successfully on the 1/4 Mile on 2nd time.
At first time 200A fuse was blown away!
173VDC, 5 Ah batterie.
70kg weight of the bike.
118,23km/h,
16,884 sec.
reaction time: 0,8 sec (very bad, because they put me in Funny bike class which has another series by switching lamps.
I am very glad with this setup, but I know that I have a lot of mistakes by the setup (to big wheel, to heavy, etc)
Wheazel
Post by Wheazel » Jun 13, 2016 7:13 am
:D this bike is funny! The design makes more sense when its a dragbike.
For regular riding it has to be close to unusable.
Good work on creating a very unique bike.
Rovi
1 W
1 W
Post by Rovi » Jun 13, 2016 7:32 am
Well let´s say the manual pedal to ride this bike was very usefull during break of first run.
I came away from the track with own muscle power, ok the bpm rise up to 179 ;-) because of the heavy weight (70kg).
In Germany daily use at the street is forbidden!
macribs
1 GW
1 GW
Post by macribs » Jun 13, 2016 12:48 pm
Would love to see a pic of this bike beside a "normal bike" to get a better understanding of the scale of the bike.
Should be great on the drag strip. Maybe dual drive to get more grunt from the green light?
Rovi
1 W
1 W
Post by Rovi » Jun 14, 2016 1:36 am
Give me some time to do this, meanwhile here a some photos from a photograph where I get the ok to present them.
Up to 100km/h the the speed curve is abrupt then the speed curve will be more flat.
I think to order another 5Ah and put them in parallel, hope to have more power.
https://connect.garmin.com/modern/activ ... NI9J.email
For better acceleration I have to use a smaller wheel diameter or another motor.
For 2WD the weight will also grow up!
Side view
... waiting on green
... on the way
pucksterpete
Post by pucksterpete » Jun 17, 2016 3:27 am
any video of the run?
Optim Alp Hardtail with MXUS Motor
20S 2P Turnigy 5.0 Hard Case
Top speed 38mph tops :)
Hyena Special
https://endless-sphere.com/forums/viewto ... 97#p585997
Excelsior/Strong GTS with Cromotor
24S 3P Turnigy 5.0 Hard Case
Top speed so far 53mph
https://endless-sphere.com/forums/viewto ... =6&t=46993
Rovi
1 W
1 W
Post by Rovi » Jun 24, 2016 5:57 am
pucksterpete wrote:any video of the run?
Sorry, not from outside view only from view of the driver.
So there is filmed the whole run. Starting point from the tent, going to the starting position, the run (8:XXmin), and back to the tent.
https://www.youtube.com/watch?v=0YOPGHjnQzM
I have no rival beside me, because I was the only one with electrical bike, so I run a demo!
leew
Post by leew » Jun 24, 2016 7:12 am
That controller explosion was rather spectacular! and I thought this was spectacular! https://www.youtube.com/watch?v=UWcPZBZl3lk
Building: Quest XS E-45, 3854Mpge (imp) (estimated) at 25mph.
Rovi
1 W
1 W
Post by Rovi » Aug 02, 2016 3:26 am
Next update in progress!
Wind shield of Ducati 1199 Pangiale
1st E-Bike Update 004_2_klein.jpg (176.6 KiB) Viewed 1792 times
1st E-Bike Update 047_1_klein.jpg (114.14 KiB) Viewed 1792 times
Rovi
1 W
1 W
Post by Rovi » Aug 07, 2016 12:01 am
First test build
Rovi
1 W
1 W
Post by Rovi » Aug 08, 2016 1:18 am
Some additional pics
08_08_16 027_klein.jpg (169.71 KiB) Viewed 482 times
08_08_16 020_kleina.jpg (189.06 KiB) Viewed 1688 times
08_08_16 019_klein.jpg (169.32 KiB) Viewed 1688 times
Rovi
1 W
1 W
Re: Andre´s STRAIGHTLINER RISING SUN
Post by Rovi » Aug 09, 2016 7:12 am
Now additional 7 batteries reached me and I can start to build a second on top box.
Rovi
1 W
1 W
Post by Rovi » Aug 11, 2016 12:44 am
The correct screws reached me now to finish this project ...
https://youtu.be/IsgyU6ncFqY
Wind shield update 017_klein.jpg (156.78 KiB) Viewed 482 times
Rovi
1 W
1 W
Post by Rovi » Aug 15, 2016 12:41 am
Saturday = washing day :)
Rovi
1 W
1 W
Post by Rovi » Aug 16, 2016 2:05 am
Starting update of the box, that there can be implement 173VDC/10Ah
update Box 002_klein.jpg (195.38 KiB) Viewed 481 times
update Box 006.JPG (145.81 KiB) Viewed 1458 times
