Hi Everyone,
my name is Jenso from Germany.
I´m a Kite and Kitelandboarder, have some Rc Knowledge and working as a Millingmachineoperator.
So i decidet to build up an EMTB based on my excisting Trampa Kite board.
Started with one Motor Rearleft, then a second on diagonal Frontright, and at the moment Dualrear Setup.
I think its most fun with the rear drive, drifting and carving and so on
Using parts from RC i had still left from my RcCars :
Hobbywing 150A ESC
Spektrum DX3R
Hyperion Duo Charger
New parts are :
2X SK3 6374 168kV
6S2P 5800mAh ZippyCompact
Using a 4mm Chaindrive with 6mm pitch.
The gear Ratio is 4.15
Milled Aluminium Motor mounts from 10mm 7075-T6
Tracked the Speed via mobilephone gps about 30kmh, more then enough for offroad i think.
Set the Timing from the ESC to the max, now its really nice directly driveable.
For sure from deadend you will notice a bit cogging but not much, see the video.
Not really sure if it will being better with shorter gear ratio from 5:1 or 6:1, maybe its more a "sensorless motor" problem. What do you think?
I get really into the EMTB Stuff and i LOVE IT
THX to the ES Forum, many great builds and loads of knowledge up here!
Best Regards
Jenso
https://www.youtube.com/watch?v=zjZafqjvnME&feature=youtu.be
Hobbywing 150A ESC
Spektrum DX3R
New parts are :
2X SK3 6374 168kV
Best Regards
Jenso
