ZeroEm
by pwd » Aug 05 2021 5:43pm
Where is a repeatable place to get one of these mxus 3k v3 (3T) from? I don't mind buying from Aliexpress; but I want to make sure I'm getting the real thing.
Are you getting two?
That will be exciting.
Thanksmarkz said:I bought mine right from the manufacturer, specified what turn count kv I wanted, she is a heavy beast.
edit
I got the V2 with alum instead of stamped steel inside the motor
Not sure what the V3 is, maybe curved magnets hype or theres something to it... and 2 sets of phase wires.
Maybe V4 will be a solid axle with different wire routing, or through axle shenanigans. Time will tell.
pwd said:Where is a repeatable place to get one of these mxus 3k v3 (3T) from? I don't mind buying from Aliexpress; but I want to make sure I'm getting the real thing.
ZeroEm said:by pwd » Aug 05 2021 5:43pm
pwd said:Where did you contact the manufacturer? Aliexpress? Alibaba? Do you have the store name I can look for?
pwd said:Are there any other choices for a 205 45H motor besides the MXUS 3k turbo / XFO 45H? I need something that fits dropouts no wider than 142MM like the MXUS 3k.
markz said:One broken magnet, measures 45mm x 14mm x 2.83mm
Not bad for a few years of service.
https://www.umagnets.com/c/neodymium-magents/neodymium-block-magnets/page/3/
50mm x 15mm x 5mm N35, Coating Nickel-plated (Ni-Cu-Ni), Max. working temperature 80°C
$3.99
Would grinding work on something like that?
ebike11 said:markz said:One broken magnet, measures 45mm x 14mm x 2.83mm
$3.99
what sort of motor probelms did you first see with a broken magnet like that? does the motor still run smoothly?
Luckily I havent had a broken magnet
kaning said:What is the difference between V2 and V3 MXus 3k motor? Not sure i missed something, thanks!
pwd said:Thanks, I'm surprise the Crystalylte H55 series says it fits 135mm rear dropouts; I would have thought it would have to be wider for a 55mm wide stator motor. Any other options/manufacturers for decent 45H hub motors? I'm looking to stick with motors under the 10kg mark.
Where is the best place to buy these motors
Yeah ive replaced phase wires a few times and its always a pain.Many will make their online store try and look like the official maker, going as far as stealing the pictures.
These guys are the official.
Alibaba - Changzhou Mxus Imp.&Exp. Co., Ltd.
Changzhou Mxus Imp.&Exp. Co., Ltd. - Electric Bicycle, Electric Bicycle Motor; Electric Bicycle Parts
Changzhou Mxus Imp.&Exp. Co., Ltd., Experts in Manufacturing and Exporting Electric Bicycle, Electric Bicycle Motor; Electric Bicycle Parts and 242 more Products.mxus.en.alibaba.com
I would not know if they dabble with multiple stores on the same platform, I doubt it. That seems like something a smaller player would do. Maybe they just order their hubs from Changzhou Mxus and upgrade the hubs to fit larger wires or different dropout widths.
With 10awg wire, through the hub 3kw mxus hub I got was quite a challenge without the hall wires. If you could find wire with thinner insulation to fit inside the axle hole, it may still be a very tight squeeze, even without the hall sense wires. Obviously you want to string the thinner hall sense wires through the hole before you try to stuff the bigger wire through. PTFE teflon wire is quite stiff (harder to bend around the corner in the axle), but the insulation jacket is thick, strong and sturdy. I ground down the sharp edges of the axle entrance (inside the hub) and the exit where the wires come out. If your still having trouble stuffing wire, use pliers, use a lubricant of some sort. The first phase wire is the easiest, the third phase wire was always the hardest. I used 12awg ptfe teflon. Some people used the stock phase wires, snipped the phases at the exit with enough room to attach way thicker phase wires, they did not notice much performance downgrade. But then again they werent speedaholics, or going for max efficiency or anything, they were just having fun with their 3kw hubs in Atlanta using Lipo and testing lipo, his content/posts were quite good - Icecube57
Anyone knows, which size of simmering I have to buy for 3k v3? If I want to add second one.
Rotary Shaft SealWhat is a "simmering"? I've only read that word used in reference to cooking. :/
