Thanks. front sprocket is the stock one and rear sprocket is 43 teeth. And the wheel size is 12 1/2.Wow this is so sick. I love this project.
I have this motor which I am working hard to mount on my bicycle. I have not seen many people using this motor it's been difficult get info about it's perfomance in the real worls
Can you please share the Teeth count of your rear sprocket and the diameter?
What is the size of your wheels?
Do you know your gear ratio?
Cheers
Thanks! Now I can calculate the gear ratio for my bikeThanks. front sprocket is the stock one and rear sprocket is 43 teeth. And the wheel size is 12 1/2.
I had a spare rim so I replaced it with it. But I think that I will upgrade the rim to something more strong so its not going to break so easily.Nice, a new pancake I havent seen..... good job on the pancake
The kind of damage that all goes straight into the rubbish bin.
You going new rim or used rim with real spokes?
Yea I have little storage room where I can warm my bikes if I need to charge batteries. If the storage room is full then I can charge right after riding because batteries are heated from the riding, but then the charging current needs to be high enough so the batteries stay warm from the charging current.Looks sweet!
How are you handing your battery charging/discharging in the cold? Presumably, you have somewhere indoors to store it, let it come to room, temp, charge it, then take it out for a ride while the battery is still warm/room temp.
Today I tested my spike tyres on the ice. Grip was really good.
that would be painfulJust don't accidentally run over your toes.
Yes its fun to ride on ice, but its also pretty cold At some point its going to rain so much snow that its almost impossible/harder to ride with small bikes like this.Nice!
What a large playing "field". I would almost want those freezing temperatures here. Almost...
