I was initially going to rip it all out and replace with a vesc and thumb throttle, but the torque sensing crank has grown on me and isn't supported in vesc as far as I can tell.
Are there any 3rd party adjustable controllers that support torque sensing cranks?
Or is cycle analyst still the best way to go?
The CA is probably the most universal way to do TorquePAS. I'm using it with just a cadence sensor on SB Cruiser and it still does almost everything I want it to, other than startup from a complete stop. (but since the system is geared VERY low in case of system failure, that's not really a crippling issue, so I haven't done anything about it yet, even though I already have the TS on the trike).
Which specific sensor does it use, and/or what specific output type does it use?
If it's a canbus-output sensor, I don't know of anything that can read that, so you'd probably have to replace the TS unit too.
Iit's possible I misunderstood the results of this thread (I only glanced thru it just now)
I'm reviving a kid bike I started years ago. I finally got a decent (48V 9.6Ah) battery mounted and swapped out a faulty BB connector/coil. It works! It's back to where it was. Now I need to tweak the software. I've always controlled it using only the T9 torque sensor feeding ADC1 in ADC...
endless-sphere.com
but it appears to be using a torque + cadence sensor along with the VESC ADC input successfully; it has no throttle.
This post
Thinking about trying out a setup with an erider torque senor bottom bracket on a VESC. From what little I've gathered, it would seem you need to get it power (5-15v and a ground) and then plug the torque+speed lines into the RX/TX on the VESC. - https://github.com/vedderb/bldc/pull/243 -...
endless-sphere.com
indicates the OSF for Lishui supports TS
Another post in that thread
endless-sphere.com
says casainho created a device/code for giving VESC torque sensor input.
There's other stuff found in this google search but I did not peruse it all; don't know if any of it is relevant or useful.
