cwah
you should definitely pitch doc!!
O yeah, that would be pretty awesome. I'd have to imagine we demand a performance from LFP alsoThat being said, there is no way of knowing what bike would be quickest without pitting them against each other.
recumpence said:drewjet said:Matt,
As usual, your build are awesome and inspiring.
As for Delta Wye switching. I have run a Delta Wye switch, using just a manual switch on my mountain bike that has your V1 Drive on it. I love it. 2 reasons, 1 is that it makes it easier on the controllers and motors if you are doing slower speeds, and 2 the increased throttle control at lower speeds doing single track riding where control is extremely important.
Any info on the "other" controllers you are testing out?
Geeze, I have no idea....
I would say that the problem with his setup is two wheel drive becomes useless when the front gets light. All of the power my bike makes is delivered to the rear wheel. So, I can actually put that power to the ground. That being said, there is no way of knowing what bike would be quickest without pitting them against each other.
Matt
cwah said:recumpence said:drewjet said:Matt,
Matt
I've seen your video and... I wouldn't be so sure. I'd say with all this power on 1 wheel it will tend to wheelie very strongly so you can never really accelerate to the maximum. But a 2 wheel drive you have better traction (so you spread the force) and the front wheel is actually pushing the bike down!
Most of the time 2WD have better start than 1WD, so I wouldn't be surprise by a better acceleration for the same power.
I totally agree.Ohbse said:Drag races are usually won or lost in the first 40 meters, if Matt's machine can leave the line cleanly at the limits of its geometry (hovering the front wheel) it has a good shot at the win unless there's a absolutely huge difference in top speed. Doc's machine might have an advantage in the middle of the run but unlikely to out launch - 2wd is no advantage at all (and probably very scary) when you're geometry limited and pulling a wheelie. I'm not familiar enough with how the Adaptto controller deals with speed differential between the two controllers, but if you end up putting down the front wheel spinning at 120km/h with the bike only going 30km/h you're probably gonna have a bad time. It's not a situation many people on earth would have experienced!
As I pointed out to Doc some time ago, it's possible to calculate exactly how much wheel torque (and hence power) you can put to the ground if you can measure the complete weight and centre of mass of the bike with you on it. This can be used to much more accurately model acceleration and will pretty precisely deliver a best possible ET. Things are slightly more complex in the real world of course, but you're certainly not going to go *quicker* than the physics allows. How much slower you end up going is down to quirks of the specific bike, skills/balls of the riders and the ambient conditions. 2wd may be awesome and a big advantage in many circumstances (I don't know first hand) but I can state for sure that it's not the best for drag racing.
Doc doesn't really want to build the best drag racing bike, he wants to build a super unique 2wd beast. Totally awesome and something to be encouraged, but it's not a recipe for quick 1/4's If you want to go proper quick then emulate the man that's already done it! Lukes bike is long, low, not particularly lightweight and leaves the line HARD.
dequinox said:Yeah Luke's bike is, for lack of a better phrase, "f%$#ing scary", and that's my impression just from watching the videos.
Matt- Any idea what to expect for Wh/mi? I'm always interested to see what my fellow chain-drivers are getting...
recumpence said:dequinox said:Yeah Luke's bike is, for lack of a better phrase, "f%$#ing scary", and that's my impression just from watching the videos.
I average 33wh per mile for most of my riding.
Matt
