MitchJi
Hi Matt,
This bike is as nice as the Motoped. Maybe you should produce frames for sale?
recumpence said:StinkyGoalieGuy said:Matt, when you originally cut the tubes on this frame and welded on the plates to build the battery box, how did you square off the ends of the tube? I assume it never left the frame jig. How critical is this "squareness"?
I used a grinder with a flap disc. I tried to make all tubes and plates as tight as possible. I would say 2mm gap is the largest gap I had to fill.
Tight gaps and clean material makes TIG welding so much easier and stronger.
Matt
MitchJi said:Hi Matt,
Yup exactly. When embedding aluminum in carbon, normally one layer of fiberglass is used as an insulator. Titanium does not have that problem. You can embed titanium in carbon fiber directly without a problem. In fact, Pagani weaves titanium stands into their carbon fabric creating "Carbotanium".Chalo said:Carbon fiber to aluminum joints suffer galvanic corrosion and poor long term adhesion unless they are electrically isolated from each other. This is typically accomplished with a thin intermediary layer of glass.
dequinox said:Gyaddaaayyuuum! That thing rips @#$%#! What a beautiful build Matt, as always... and completely shattering the concept of form vs function.
Thanks for the inspiration! Any care to put a $ figure on what went into this? If I had to guess I would say close to $6k. Did I miss the mark?
drewjet said:Matt,
As usual, your build are awesome and inspiring.
As for Delta Wye switching. I have run a Delta Wye switch, using just a manual switch on my mountain bike that has your V1 Drive on it. I love it. 2 reasons, 1 is that it makes it easier on the controllers and motors if you are doing slower speeds, and 2 the increased throttle control at lower speeds doing single track riding where control is extremely important.
Any info on the "other" controllers you are testing out?
drewjet said:Matt,
