I'm joining the fun with the little 14s version of these. I've begun reverse engineering and hope to figure out how most of it works.
To test any FET to see if it is on or off, measure the voltage across the two outside legs. Zero volts = off, over 5v = on (but most FETs want at least 8v to be fully on).
It seems it doesn't like turning on against a load when you switch the thermal breaker. I'm planning on revising the circuit on mine so it can be used as a precharge/main contactor.
