major said:
dnmun said:
if you ask which of their models you are interested in we can tell you prices. i have a list i got from henry 3-4 weeks ago for some i was interested in. but i recommend the D131 for all of applications you are thinking of. all the other BMSs are smaller and have a much lower balancing current. the D131 is $58 for 24S and the D126 i am using for 15S was $19.
Thanks. I inquired about the HCX-0131A for 12S cells at 4.2 volts per cell, Balancing/Equilibrium Modules. I want to use it (them) on EnerDel 2P12S modules (35Ah) independent of charger and load.
they do not sell this D131A balancing board it turns out. i was able to talk him into donating one to me that did not have the HVC and LVC components mounted so i could examine the traces hidden underneath the surface mount parts. that was what i put in the picture.
if you want to use just the balancing board and use their HVC and LVC signals to drive your enerdel controls then i would recommend that you order the D131 and hack it by either using their mosfet gate driver signal or even use the entire BMS itself for current control. the 80A is very conservative. they have 15 of the irfb4310 in parallel. each one is capable of 30A easily imo. the shunt wires can be hacked to increase the cutout current from 180A up to maybe 300A imo. that overclocking of the shunt is still only 20A for each of the irfb4310. most use them in the hi voltage controllers at 100V on top of that are used at 80A in the controllers and the controller pwm switches them at high frequency so i think the current rating is overly conservative given the huge heat sink and thermal breaker.
i think it is maybe even 400A capable. 150 continuous.
maybe if enuff people get interested here in the states it would make sense to combine a few orders into one and then use the small flat rate box in the states to split it up. but shipping is the biggest component of the pricing now because these guys are selling us these units at really low distributor level prices imo. that is why i worry that someone is gonna screw it up.
