evolution9
- Joined
- Apr 17, 2014
- Messages
- 37
Good Morning,
I've got a big Chinese scooter with a massive 1000-3000W hub motor, phase wires are big. I currently have a 60V 20 AH SLA battery and a stock controller.
I recently purchased a 12 x 4110 MOSFET Extreme Modder Controller LYEN Edition (initially programmed for 72V and moderate Amps) and......
4 x 48V 10AH LiFePO4 batteries ( http://item.taobao.com/item.htm?_u=i1q92q42feca&id=10937763942 )
The batteries were relatively cheap $90 USD ea and have the following ratings:
Rated Discharge Current: 20A
Maximum discharge current: 35A
Rated charging current: 5A
Maximum charge current: 10A
They each come with a BMS which is why I believe the discharge rate isn't on par with a typical cell. (I may be wrong on this)
My initial goal was 96V and 20 AH (2 batteries in series and 2 batteries in parallel) Will this work? Can I expect to draw more than 35Amps? Will the BMS prevent them from being wired in series?
Will this configuration work? Could I program the controller for 96V and less amps? I could always buy another higher voltage specific controller. I think I may have jumped the gun on both the batteries and controller purchase, but I'm impulsive like that.
Would I need to modify the controller (bigger traces, shunt, wires, etc?) If so, I think I could follow a guide and get it done.
Thanks for the advice.
Bryan
Bryan
Bryan
Bryan
