MD.
1 W
Hi ES,
I'm planning on buying one of those Sun-Thing 48v 15ah LiFePO4 batteries and I wanted to make sure it's compatible. My new setup consists of a 9c 2807 with a generic 25a controller. Right now I'm running it on 12s 3p of HK Turnigy 20c lipo. I'm using one of those budget watt meters and it reads about 27a at 48v for about 1300 watts at WOT. The battery I'm looking at is the one in this link with the specs pasted below. What I don't understand is what maximum sustained work current vs maximum discharge current means. When I ride I usually just throttle up and down but sometimes I go full blast for 5-10 minutes to get up the hill to my house. I read dogman's post on electricbike.com and I think I'll be ok. I'm just not 100% sure and I hate wasting money.
Here are my questions.
If I run at WOT (27a) for 10 minutes straight to make it up the hill to my house, will that damage this battery? This hill will be nearer to the bottom of the charge as it's on my way home from work. I will have used about 8ah to get to this point in my journey to and from work.
Is this battery underpowered or ok for my setup?
How are those Sun-Thing batteries? I know they're not Ping or Cell_Man quality but are they better than victpower? Will I be one of the first to test them?
My controller cutoff is around 29.5v, will the BMS prevent over discharge so that I can ignore the controller cutoff? Or, do I still need to monitor AH and voltage usage with my watt meter?
It comes with a 3a charger but says I can charge at a max of 7.5a. Is there an affordable place to get a 7.5a charger for the fastest possible charge? I'm ok with changing out components or soldering or anything else electronically needed to fix this stuff.
Thanks in advance to anyone who responds! This forum has been a huge help and I can't thank you all enough!!!
http://www.ebay.com/itm/130656251541
Specifications
Nominal Voltage 48V
Voltage Range 42 - 58.2V
Rated Capacity 15Ah
Over-discharge Voltage 2.100V( Any cell)
Over-charge Voltage 3.900V( Any cell)
Charge Voltage 60V
Open Voltage after fully charged 51V~57V (1 hour after being fully charged)
Maximum Charge Current 7.5A
Estimated Charge Time @3A About 5 hours
Discharge End Voltage 41.0-42.3v
Maximum sustained work current 20A
Maximum Discharge Current 35A
Over Protection Current 45A
Temperature Rise ≤25℃
Operation Ambient Temperature
Charge 5~50℃
Discharge < /strong> -20~50℃
Cycle Life ≥1200times(Cycle@23°C,0.5C ,100%DOD)
Storage Temperature Range Less Than 1 Year: -20~25°C
Less Than 3 Months -20~40°C
Weight About 6.4kg
Size 260*180*90(mm)
Colour Epoxy board packaging + silver tapes (silver)
This battery is include BMS AND 3A CHARGER.
Specifications
Nominal Voltage 48V
Rated Capacity 15Ah
Charge Voltage 60V
Charge 5~50℃
Weight About 6.4kg
Size 260*180*90(mm)
