I cleaned up a 8FUN front 250w geared hub motor that was badly rusted internally, I mean really badly. I'll post some pics later.
After the clean up, it ran fine on the bike for a few days. After briefly stopping on a ride, I set off again and the motor was noisy and ran rough for a short while then died. Then worked again but it felt like it wasn't pulling at full power. Then died and is now intermittently faulty.
Got home and have done some testing. Luckily, I have another identical bike so the motor is definitely the problem.
I've opened the motor up. With the throttle sometimes the motor will start spinning on its own. Other times it won't spin but I can hear it hum and then click. Like it's trying to start spinning. Once going providing i keep it spinning, I can back off the throttle to just before it stops spinning and it'll keep going.
It seems in some positions it won't start spinning but in others it will. What does this mean?
From the rust the bearings sound rough and are loose but they run freely. The only other difference is this motor when unplugged doesn't run quite as smoothly when turned by hand as the non rusted one. Like the magnets are sticker. Buts it's consistent, there are no positions that are sticker to turn.
I don't think it's a short as providing the motor doesn't stop spinning I can vary the speed without any issues.
