I know that you don't want to talk about pros and cons of front hub motors but I think you should. A front drive motor at 10, 15, and maybe even 20 miles per hour will behave much differently than a front hub motor at 30 or 40. At 40 mph if you try turn the bike without countersteering, the result will be less efficient turning and possibly even a high side if you turn the front wheel in the direction that you want to go. If you countersteer with the front wheel under power you just are asking for the front to slide resulting in a low side (better than a high side but they still hurt).
So the question is: Why do you want to build a high power, high speed bike with a front hub when even if you can build a fork that can handle it, it will be so far behind a rear wheel build in terms of stability while turning. If the answer is to just do it to see if can be done, then I say go for it. but, if you think that there will be any advantages to it in terms of performance, then I think you will be severely disappointed.
Sorry to break your rule but other people who might not know this might read this thread and think it was a good idea.
