My Sun EZ-Rider CX. Dual 52V drive systems. Bafang BBSHD mid drive for hills and a Bafang 500W rear hub for cruising.
Thanks. It’s been a lot of fun. I’m sure you know the feeling.Gorgeous build. You've clearly put a lot into kitting it out nice. Thanks for sharing.
I was asking someone a couple months ago about this very subject , regarding cars however it should be the same with a trike.
Brakes...important when hauling a trailer, but you can build brakes into a trailer, too, and there are even ways to make them auto activate based on hitch tension/pressure (some discussion on those in one of my trailer threads, I think). If the trailer has brakes of it's own, it's less important that the hauling bike/trike has stopping power for both of them.
Another problem with a delta trike pulling a trailer is that (again depending on hte hitch and load) in a sharp enough turn or avoidance maneuver, the trailer can push the trike and tip it enough to flip them both over.![]()
The reason I don't yet have a 3 wheeler is that a Tilting Delta Bicycle is not yet available . I talked many years ago with a A and PI've already got an upright bike I've been using and it does work well (and has disc brakes) I'm looking for a recumbent for comfort reasons, I've tried a lot of different styles of upright bike and I just find they always leave me sore. Whereas the few times I've gotten to ride recumbents they've been like couches
What would be the main thing that would shy you away from a three wheeler?
For what purpose? Unless you wish to travel in excess of ebikes legally restricted speed limit or ride in competitive events, I see little need or advantage. It complicates the build, bloats the cost, and adds unnecessary weight. If you are intent on cost & complexity... spend it on suspension instead.The solution is to make a tilting trike
I talked many years ago with a A and P mechanic who was building a trike using parts from a off road quad , he said the main problem with reverse trikes is that they need
to have allot of down force on the single rear wheel . That eats up allot of energy .
Steelrazor,My Sun EZ-Rider CX. Dual 52V drive systems. Bafang BBSHD mid drive for hills and a Bafang 500W rear hub for cruising.
even though you say the rolling resistance would be the same in both types of recumbent his point was
that with a tadpole trike it is very easy for the rear to slide out sideways , so the designers design them with allot of
weight on the back , so with more weight and or down force on one of the wheels then it has More rolling resistance ?
Interesting , so then a tadpole trike design could have less weight on the front wheels which would not be so good for traction and or handling , I wonder if that is why so many of them have the riders weight so far forward and legs and feet often in front of the front wheels .No, adding weight to a wheel does proportionally add rolling resistance, but when that weight is removed from the other wheels their rolling resistance is reduced by the same amount (if the wheels are all the same).
