numberonebikeslover said:
In few minutes of desperation when I was unable to access ES I realized that I can't imagine to live without ES. It has become a part of my self now and how difficult and painful it is to be away and not being able to stay in touch. I love this global brotherhood of people from all over the world. Indeed there would be others like me who strongly consider all of us as brothers and sisters. To join hands to change the world with love and peace I understand ES is playing its role which will be no doubt written in golden worlds in the books of history.
Naeem is referring to a little friendly-fire accident we had. In an effort to slow down the constant attacks by spammers on the forum, we've been banning certain IP address ranges. Unfortuantely, Naeem tried to access the forum using one of the banned IPs and was locked out. I see he's able to post again, but this could possibly happen again. Sorry about that!
The moderator team is constantly trying to improve the anti-spam measures but on some days we just get blasted with so many it's hard to keep up. Anyway, that's a whole separate topic...
Naeem: on your motor, there is certainly a limit to how high you can run the voltage and still have improvement. If the motor RPM goes too high, more power is wasted by wind resistance and iron losses. The trick is to find the best operation range. Motor heating is a good indicator of losses in general. A motor like yours was probably designed to operate around 3,000 rpm. My guess is the losses will start to become a problem above around 5,000 rpm.
If you look at a graph of motor efficiency, the peak is usually close to the unloaded speed. At no load, the efficiency is zero. At stall, the efficiency is also zero. At the maximum power point, the efficiency will usually be not so good. If you can gear the motor so it runs close to the maximum efficiency point most of the time, you'll minimize heating and maximize battery range, but you may need to sacrifice some speed to get this, especially on hills. Ideally, you'd want to be able to change the gear ratio while riding.
Below is a motor graph for a brushed motor. While the scale will be different for your motor, the general shape of the curves should be very close:
