They work fine for me; Iv'e worn out one set and am on my second now. The old ones are now spares, presently used on a one-dog kennel trailer, on old BMX wheels.
The main reason I am not using the 3" version of this tire is simply that I'd have to rebuild the rear fender frames to accomodate them. The 2.25" ones are already so large I had to modify the frames a bit in places to prevent rubbing. :lol:
If I knew of a CST tire similar to this, I'd be willing to try those, too, as everything I've used of theirs for bicycles has been very good (and one I wish they still made; it was a really nice tire).
I'm using tubes, rather than trying tubeless.
The only time I've seen any problems with the tire rotating on the rim are in severe underpressure situations, when there's already a flat or near-flat, and that's been so rare (four times? five? so rare I can't recall :lol: ) in the years I've been running these that I haven't had enough observations to determine anything from it.
At least two of the flats were caused by valve stems on bicycle tubes, so now I use metal-stemmed MC/moped tubes, and don't have that problem..another was caused by failure of the rim strip tape, which i'd used cheap electrical tape for, and the tube got notched by the nipple holes. Another was a super long thorn, probably mesquite, which didn't actually cause the flat--pulling it out caused the flat; the thorn kept the hole sealed until then. :lol: The tire is so thick that it held the thorn in place in the hole in the tube so well it didn't leak much till then. :/
