Ianhill
- Joined
- Sep 25, 2015
- Messages
- 2,871
With that motor I wouldn't use a torque arm like I've got it will still deform its too strong the mxus can top out at 100Nm of torque and to shove that into a bike frame without having troubles is asking alot you have gone for a even bigger bad boy that will have over 150Nm proberly with the right controller that just wouldn't be good news for the swing arm on a standing start launch, if you have any weight to you things will only be worse.
The torque arms need to be around 8mm tool steel, stainless won't cut it and it will have to clamp the axle too just interference fit will oval over time, you can clamp it down with out an issue but will the rear hold up over time hmmmmm it's taking more than 10× design force ?:/.
I hope all goes well for you have spent alot on it clearly but worse case scenario you will need a new frame when this sucker takes a dive just hope it don't hospitalize you in the process.
