RageNR
- Joined
- May 23, 2016
- Messages
- 216
Ok, I am gearing up to do this. Currently have my hands on 170+ 18650 cells pulled from a Tesla 90kWh pack.
My pack configuration will be a 24s7p overall, but I will be splitting it up into 4 smaller packs of 6s7p each. This is for several reasons:
#1 Flexibility (can run 2, or 3 or all 4 packs. Range limited, of course)
#2 Each pack will be 24v (easier to manage. Can be used in multiple applications)
#3 Separate packs offer flexible size config and placement
#4 Redundancy (in case one of the packs suddenly goes bad. Can still run 18s @ 65v or even 12s @ 43v)
Each cell is 3.6v nominal and ~3200mAh. So about 11.52Wh per cell. With 168 cells, that is around 1,935Wh for all the packs combined.
What I need to figure out is how to setup the charging. These are Tesla cells, and are safe to fast charge. I want to take advantage of that when I am OUT on the bike and may need a quick top up.
Mobile charging equipment will need to be as fast and small as possible. Here are my considerations...
- On-the-go charging units: Turnigy Reaktor 1000W 30A, iCharger 3010B, or iCharger 308 Duo
- Home chargers: Multiple smaller capacity Turnigy/iMax/iCharger chargers, Turnigy Reaktor QuadKore, or Turnigy MEGA 1344W 40A
- Charging power supply units: Server power supply units from either HP or Delta. 1000W-1400W range
I am really considering the Turnigy Reaktor 1000W. That would give me a 2hr recharge time for the 1,935Wh capacity, or ~1hr for a 50% charge.
What I am wondering though is, could I forgo the Turnigy while I am out and trust only the Server Supply to give me a quick charge? Mind you, I am talking a partial recharge, NOT to full capacity. If I could adjust the server supply to top out at 24.6V, that would give me a 4.1V charge per cell in 6s config.
edit: (this would require 2x server supplies cause they're 12V each. Prefer to only have to carry 1, so that's the reason for 24V packs and 12V center-taps on each)
I am also considering adding a center tap to each pack, for 3s @ 12V applications. 12V could possibly be used for charging as well.
What are you guys thoughts? Got any input or advise for a setup like this?
Picture for reference:
