Doctorbass
I discovered on the Junsi website a new device for datalogin and multi use.
it do the same as the celllog but it also have 3 temp input, do the same as a wattmeter, and ampmeter and measure PWM caracteristic and more!
49.99$
ere are the features:
Specifications
Input voltage range: 4.5 – 60.0VDC
Current measurement range: -130A – +130A(continuance -40A – +40A)
Cell voltage range: 0.05 – 28.0VDC
External temperature measurement range: -55℃– +125℃ (-67 oF–+257 oF)
Pulse measurement range: 10us–999999us
Pulse width output range: 0–20ms (0.5us step)
Tachometer measurement range: 0–99999 RPM
Voltage resolution / accuracy: 0.001V / 0.5%
Current resolution / accuracy: 0.01A / 5%
Current loading of test: 12mA
Maximum voltage for alarm port: 50VDC
Current drain for alarm port: <500mA
Log files storage: 16Mbit (33 hours@2 seconds logging interval)
Sample logging time interval: 0.25 – 3600 seconds
PC connect: USB port
Weight: 29g
Dimensions (L X W X D): 85X40X13mm (3.34‖X1.57‖X0.51‖)
Special features
ï¬ PowerLog 6S allows bidirectional current sensing, adopting 0.2 mΩ current sampling resistor with low
insertion loss.
ï¬ 1 channel 0-60V voltage measurement. 6 channels cells voltage measurement (can not only measure
1-6S Li/ NiMH/NiCd/ Pb battery individual voltage, but also measure 6 channels 0.05-28V voltage)
ï¬ 4 channels temperature measurement (1 channel internal temperature measurement and 3 channels
external temperature measurement)
ï¬ Propeller RPM measurement, adopting non-contact optical sensing, user settable blade number.
ï¬ PWM signal measurement: frequency, period, pulse width, duty cycle. Applicable to remote control
channel signal, measure, and monitor.
ï¬ PWM output: manual and auto mode, auto mode is able to break in servos, electronic speed controllers,
R/C switches etc.
ï¬ Motor KV measurement. The 2-wire mode is suitable for the KV measurement of brushless motor; while
3-wire mode is suitable for the KV measurement of both brushed and brushless motors.
ï¬ Small size with multiple functions, backlight 128*64 lattices LCD and Buzzer Tone Reminder; the
interface can be operated smoothly.
ï¬ It can be set Cells Voltage/Pack Voltage/Timer Over/Current/Power/Capacity/Temperature/RPM/Period
and Pulse Alarm. What‘s more, the extra alarm output can be linkage controlled by the users.
ï¬ It has 8 sets default monitor alarm settings, which can be selected for different battery packs.
ï¬ PowerLog 6S has been 100% calibrated before it enters to the market, at the same time, it supports the
calibration by users themselves.
ï¬ The logging interval can be set by users‘ different needs. PowerLog 6S has a 16Mbit flash storage,
which can log offline data in 33 hours @2 seconds logging interval.
ï¬ Support upgrading the hardware program by USB port. Adopting HID protocol, dispense with installing
driver from PC, plug and play.
ï¬ The PowerLog 6S supports the ―Logview‖ software and can display, plot and analyze the data by it. (See
detail information about Logview in the following website: http://www.logview.info)
The link for the manual: http://www.jun-si.com/UploadFiles/PowerLog6S.pdf
Doc
49.99$
Specifications
Weight: 29g
Special features
insertion loss.
R/C switches etc.
Doc
