ngocthach1130
So...about a week ago i decided to lower the rear by changing the wheel from 26" to 24". I figure it was an easy task. Planned out everything. ordered 24" rim,spokes , tube, tires. Rim brake won't work anymore so ordered disk brakes. Front and rear just so they match. OCD can be annoying sometime. Got new fender to accommodate larger width tire too. Got double leg kickstand cuz with smaller wheel the bike will tip over because the current kickstand is too long. New rear rack so some of the battery weight will be put on the rear swingarm instead of seatpost. Everything came to about 300 dollars in parts. Both brakes alone was about 100 something already.
Stuff came yesterday. I was so gungho about it i spent the day removing wheel, rim spokes. Ugh trueing a wheel is a bitch. Got it to wobble as little as possible but still pulsate. Respoke to new wheel and mount on the Schwalbe big apple. Then it hit me. Damn Schwalbe was so big even though it's 24", fully inflated it is almost the same as my 26" knobby. Okay so no ridn' low yet. I also notice i somehow dished the wheel offset to the right a bit. *sigh* got to fix that later. Installed other stuff, rack, fender, kickstand. I was going to leave the brakes for last. Took off the front disk brake off. Mount the Avid BB5. No problem. Then i move to the rear and OMG damn caliper won't clear the hub. I don't have enough clearance for disk. Fack fack fack. It never occur to me disk brake won't clear the damn hub. Shit, now i'm stump. Either i work up a huge rotor and custom mount for the disk like hal9000 did, which mean mucho money, or i need some resistive brake system which short the motor to some coil. i could run with front brake only. But dunno if i have the balls too since i ride average 28mph down a hill on the way to work everyday.
Moral of the story is. Don't order all the shit before you measured everything, then measured again. Crap.
