Voltron
Nice circling back :wink:
wturber said:I like the idea of standardizing these rules across the various states - if the rules are good, sensible and an improvement on what is in place.
Crossman said:Anybody having experience with this dongle the bosch maintenance log when you take the bike for a firmware update ?
Quite frankly I think there is no way only scaling the speed sensor on the wheel causing any kind of damage to the system since the only variables that matter for this system are the cadence, power/voltage/amp input, torque output which are all intact (for example exact the same cadence and torque you get at 26mph can be generated at a lower gear when you are climbing up at let's say 13mph).
Anyone know what variables the Bosch log stores ? Obviously if it has information on the actual gear ratio (what gear you are in at each moment) you can easily spot it. I realize that this dongle halves when it reaches a certain speed which is also easy to spot for the trained eye but I don't know if that can be used as a case.
thanks
