Hi guys
I'm in need of some help as I'm completely new to ebike batteries and troubleshooting them. I've learnt loads today and won't do anything I don't understand...
I have 3 48v 13ah batteries and 3 chargers. None were charging so I have opened 2 of them up.
From the BMS:
The battery voltage across the pack is 52.5 measuring B- and battery positive.
When I measure C- and the battery positive the voltage is 24.2
If I remove the balance plug with all the wires the voltage is 38.5
Currently the cell banks are around 4v each.
The charge port measures 24.2 so will not start charging.
Should the voltage after going through the BMS equal the total battery capacity? Are the above results normal?
The other battery I tore down has the same symptoms.
From the BMS:
