MikeSSS
The bike is a 1997 Mongoose full suspension, the rear hub motor is a MAC. There is no usable front triangle on this bike, and thus no good place to mount a battery in the front triangle. The new battery is too big to mount under the down tube.
The new battery is a 14s, 8p, 52v, 20ah, it weighs 12.2 lb. To put this in perspective, the gel cell 36v battery I started with 6 years ago weighed 25 lb, the 13s, 4p, 13.5ah lithium battery that followed the gel cells weighed about 6.8 pounds.
Three mountings were tried: top of a rear rack, on top of the "top tube", and along the side of the top and down tubes.
Little difference was noticed when riding. This is probably because the weight of the battery is a small fraction of the combined weight of the bike and rider. All three mountings rode well. Mounting in a bag on top of the rear rack was the most convenient.
A significant difference occurred when stopped, especially when stopped on a steep climb or when stopped awkwardly and trying not to fall. The weight of the battery on top of the rear rack could cause the bike to pivot upward and backward about the rear axle, as if in a slight wheelie. The front end of the bike could come up off the ground and scoot to the side causing balance to be lost.
The best battery location when stopped was battery mounted on the left side of the frame tubes, about where it would be mounted if the bike had a front triangle, except battery is offset to the left of bikes center plane. Yes, the left side battery location does interfere with pedaling, but I sit facing slightly leftward because my right foot is on a bit sideways. A pedal extension on the left side helps prevent pedaling interference. Installing and removing the battery is easy. The slight off center weight is not noticeable. I don't pedal hard, preferring to spin, so the pedal extension probably won't be a problem.
Battery on top of the top tube looked wrong and quickly got the stopped bike out of control when trying not to fall. Riding was not a problem though.
Well that's it, side mounting a relatively thin battery actually works pretty well. Better still, it makes a wider range of full suspension bikes suitable for ebike conversion, while using a large capacity battery.
Hope this helps somebody.
