GreatScott!
Hello, from Canada, my name is Jon.
Been glancing around this site for a while now with speratic posts here and there. Learning alot, pretty good site. Cheers for some great replys.
I have a home made electric motorcycle that I would eventually like to equip with LIPO. (will post pictures once graphics are done) I've asked around and hinted on the forums here before if a large pack, hi current type BMS is possible, have yet to get a straight answer. Hope this hasn't been answered already and is worthy of a new post.
Anyway, I have consulted with a few design engineers of LIPO EV manufacturers and concluded that it would just cost too much for my purposes. 5-12G's. Looking for a DIY solution as my bike and my current SLA packs are DIY specials. The impression I get from most sources is that there really isn't a DIY solution for a pack this large. Designing and building custom hardshell compartments, assembly and wiring, and charging them will not be a problem, I have that figured out; creating a monitoring and safety system while discharging them I need help accomplishing. For instance, will a good BMS just monitor or actually affect the discharge dynamically???????Is a BMS for discharge even necessary???? This stuff is the last hurtle I need to get by before I can build my pack.
The components are as follows:
The Motor:
48v 14,400Watt E-tek
http://www.electricvehiclesusa.com/product_p/mo-et-2401.htm
The controller:
http://www.electricvehiclesusa.com/product_p/co-axe4844.htm
This controller has the plug brake option on it which can limit the current to the motor when activated. It is used for regenerative breaking but I am not using it at the moment.
The batteries are 4X20ah 12 v tysonic batteries connected in series for 48v.
The building block packs I want to build will be 6p A123 cells slid into a tight fitting hard shell casing with six gauge wires popping out the top for quick connection along with smaller gauge for balance taps. This will be considered one cell of 3.3v 13.8Ah, the building block of the system. They will be about 3†wide/deep, 1.25â€Âlong and 7â€Âhigh. I will then butt 16 packs like this tightly together, connected in series for a total pack voltage of 52v and 13.8ah. Charging will be accomplished by one 10s charger for the first 10 packs and a 6s charger for the rest, all with balance taps connected. Eventually I will add another identical pack to this one, connected in parallel for a total of 52v and 28ah.
The controller can put pull out 400amps from the batteries, I’ve ran it at 300amps this summer and will probably bring it down to 260 for next season; not too sure what it pulls under heavy load but I doubt it pulls the full amperage setting for long, Thats more than an average house service panel!!yikes. Either way it can pull a lot of amperage, I assume more than the average 40A E-pedal bike controllers featured on this site. That means big wires for discharge and heavy duty BMS circuitry/wiring to consider.
I imagine the best people to respond to this post will be the BMS guys, any thoughts? Perhaps there is an A123 rep lurking here somewhere who can bestow some inside information. If hi current is a problem in design, the same principles should apply as with lesser amped e pedal assist BMS systems, no? Just need to figure this out.
The Motor:
The controller:
