If any cell drops below cutoff (this depends on BMS model. Usually around 2.6v) while it is under load, this will cause the BMS to trip. The cell voltages might look OK with no load.
I don't think over current is your issue unless the load is drawing over 30A.
Did you try running your amplifier straight off the cells, bypassing the BMS?
