Ok. then let's backup again to the thread Title (balancing) and your interest in just a monitor (i.e. CellLog 8M). You indicated you can balance charge your 16S LifePO4 which i questioned... That's why i previously said to another member ... "Get the picture?"
Here's your post from another thread implying your 16S pack can be split or at least has two 8S balance leads for cell monitoring ...
zeccato said:
All I care about is the monitor,
and maybe disable the balance,
I need it to charge 2 battery 16s lifepo4 without the bms, up to 90-97%..
as discussed here: but
https://endless-sphere.com/forums/viewtopic.php?f=14&t=104641&p=1529737#p1528905
When you say "charge 2 battery " ... 16S LifePO4 (?) ... do you mean you can split the 16S into two 8S packs that you combine after balance charging your two 8S packs and then again joining as a 16S battery?? Even if that was/is the scenario the only 8S balance charger i know of is the iDST Q8 smart charger ... https://www.youtube.com/watch?v=BqgEEuquX_Q ... but it's single (not available as a 8S duo ... aimed more at RC quadcopter guys. So, that's why i question whether you've ever balance charged your 16S, unless you've modified/built your own custom duo 8S charger when balance charging your two 8S packs of your 16S LifePO4 as you've previously implied.
If you had bought the iDST BattGo 8S a couple years ago, if just for cell monitoring or also bottom and/or top balancing (when necessary) you possibly wouldn't be posting now in search of an add-on overcharge alarm/buzzer. Kid you not, because two years ago you would've known if your 16S was still safe to bulk charge to 95% OR time to retire it so you don't run the risk of a
FIRE.
Please don't get upset with me, but when previously replying to another much respected member "Get the picture?" this is what i pictured. ... You have an 8 yr old 16S battery that may or may not have two 8S balance leads in the event you were hoping to still find at least one new or used CellLog 8M monitor. Or possibly you had one, but it is no longer working. The cells in your older 16S pack may now be unbalanced before and after bulk charging ... that's why you want a charger with alarm if one of the P-groups is borderline dysfunctional. Hope what you really meant by "quick charging" is bulk charging at no more than 1C and preferrably 0.5C considering the age of your 16S.. Thus your reason for NOT fully charging (maybe only 90%). Do you realize the risk of a
FIRE even to only 90% without cell monitor for bottom discharge balancing as needed (cells within 30mV min-max goal).
So, assuming you can split your 16S battery into two 8S packs with 8S balance leads attached to each 8S pack you first need to monitor and bottom balance (discharge balancing) each 8S pack to within at least 30mV if even possible. The CellLog 8M was only a monitor. The closest (best replacement) for the CellLog 8M is the iDST BattGo 8S. It not only monitors, but discharge balances as well as other neat features. So, the first thing you need is an iDST BattGo 8S or possible two with your two 8S balance leads.
That other iDST BattGo 8S video is a joke, yet good to see so you don't think every review gets reimbursed. The guy has a ton of usually good videos, but he's so busy he doesn't always do justice when reviewing a new product which was the case with that video review of the BattGo 8S. Does he actually thinks that was a fair test seeing how long it takes to discharge a cells having a disparity of 450mV higher than the other cells... give me a break! What is does show is the bias that many DIYers still think is the best 8S monitor (CellLog 8S). Once they get there hands on a BattGo and realize all it can do and will do they wouldn't use their CellLog 8 anymore.
One of the best reviews (German) ... https://www.youtube.com/watch?v=fUokWECN2cI&t=27s
This is another decent review ... https://www.youtube.com/watch?v=UIYCKYfNkiE&t=563s
So in summary the iDST BattGo is actually better than the CellLog 8M (some CellLog 8M diehards may disagree until they get one) as it can also bottom and/or top discharge balance assuming you really have two 8S balance leads attached to your 16S battery.
So, to summarize your 8 year old 16S LiFePO4 battery may need to be retired. BUT should you decide to still continue to bulk charge it (preferably at 0.5C) you first need to get a BattGo 8S if you have two 8S balance leads on your 16S battery. The battery only needs to split in two 8S packs when actually balance charging assuming you really have two identical 8S balance chargers starting the same time with the same settings or a duo 8S smart balance charger. You don't need to split it into two 8S packs with passive 16S monitoring or discharge balancing with the two 8S balance leads attached to your 16S LiFePO4 ageing battery.
Hopefully, this post is useful :wink:
