markz
100 TW
So if this serious attempt does not work, can only go down in diameter.
Mixture of Sapim double butted and them fuckin' Bavel no name generic spokes from China.
Last I counted 5 Sapims were toast on the last half ass semi-relace, its more like 10 or 12 now.
I know I know, Sapims Sapims Sapims, no generic shits. But I am cheap. The end product is going to be Sapims Sapims Sapims, but I will know after I drill out the nipple holes if it will work. AND IT WILL frocking WORK!
This is a multi-hour project. No fishing by the river today.
Any tips on drilling out rim holes?
This is my method, find a drill bit that is the same size as the rim nipple hole.
11/64'ths bit
Keep rim laced to eye ball the angle of the drill bit and do angle it to the right flange, either up or down (left or right flange)
I just did one spoke hole, I marked which angle I did it with a Sharpie marker.
Drilling rim holes is easy.
The trick I used after drilling out the rim holes with their eyelets, is I take a spare spoke, and I eyeball the nipple itself to the corresponding motor flange hole of the spoke and see if the installed spoke is inline with your eyeballing spoke. Another trick, is to drill at an angle ALOT more of an angle then it should. When you eyeball the drill bit, go beyond the corresponding flange hole to the outter edge of the motor itself. I had to do it 2 or 3 times to get it right. Just do my trick,
Here are some pics, easy to see the problem nipple angles and the proper nipple angles.
Took about 3 hours to get it all done.
Some eyelets are coming loose (but still staying on, they've just popped out a bit cuz of the drilled angle), means I am going to far (perhaps). I eyeball the drill bit to the top of the drill and go until it aims at the flange and no more.
Working good though.
Edit
OK I did a half ass lace job, nothing from scratch.... far from it. I did not take off all the spokes, and drill. I undid one spoke at a time, drilled the nipple hole, then put the spoke and nipple together again. No Boiled Linseed Oil, yet, thats my next task, to do a proper wheel build, which means using the marks I made on the rim to indicate which way the spoke is going, then taking all the spokes out and doing it right, with Sapim spokes and nipples.
I did a lot of 'just less then massive' power turns, for some reason I like to do them in the red gravel of the baseball field, plus I did 8 on pavement. I will get on tightening it all up decently and just take it easy just so I can ride. I missed my fishing trip today, 5 hours frocking around with the ebike. The end result of power turns are a handful of spokes are just loose. Two spokes broke at the J-bend of the spoke. These were, more then likely, spokes that were used on the mis-aligned nipple-to-spoke holes. The good news is the spokes always broke off at the nipple before, and a few would break off at the J-bend.
11/64'ths bit
Edit
