grandmasterE
- Joined
- May 25, 2009
- Messages
- 66
Does anyone have any experience with the BMC 1000W hubmotor yet? If so, give up the details (speeds, acceleration, batteries, and controller)
E.
E.
grandmasterE said:Does anyone have any experience with the BMC 1000W hubmotor yet? If so, give up the details (speeds, acceleration, betteries, and controler)
E.
GTA1 said:The exceptions are brands based in the US etc. like Bionx that source their own components, insist on strict quality controls, and of course, charge sky high prices.
Anyone got any ideas as to how to move this forward?
By visiting http://www.endless-sphere.com ...DahonElectric said:All they have done is offer low cost kits with powerful motors at cheap prices. How could a normal Joe and Jane know what to do with it?
Reid Welch said:.....Planetary spur gearing is perfectly efficient as any other sort of spur gearing.
....But it DOES tend to make noise. So "we" gear makers, that is, have long used silent materials for gears....
....Nylon: cheap, quiet, soft, thermoplastic that loses even more strength as heated, it then melts at some point.
....There are,.... a variety of moldable (cheap to make) gear plastics that are tough and forever. Whatever Honda uses in their one-lunger four strokes for the half time gear, is silent plastic, tough, heat proof and durable in this super-severe service. Wham, wham, wham, as the ICE engine explosions shock the gears with every ignition.
....There is no sense in using steel planets in motors of any sort.
Soft steel against soft steel (the ring) make a very poor wearing combination.
Hard steel against hard steel run in oil, like a proper auto transmission, preferably helical cut, is fine. But not soft steel running in grease, not for a long term of say, ten thousand miles. It won't/can/t wear well. And it may tend to be noisy as heck. Or quiet. Depends on the luck of the machinist. But metal against metal spur gears running at high speeds almost always are NOISE.
....Nylon is the worst plastic, practically, for this sort of ebike motor service.
It is not strong enough for long use, especially under shock loads and high temperature.
r.
Why use "cheap" non-metal gears?....64ragtop said:I've thought for years why such cheap, soft, high temperature intolerant plastics are used is because They're CHEAP!
No other reason has been presented, so there ya have it!
shady8282 said:I'm building a folder. Is there a geared hub motor out there that will go at a decent speed on a 20" wheel at 36v? Maybe I should just ask what is the fastest geared hub motor for a decent price? Advising me to increase to 48v, 60v or 72v is not necessary, I know what that would do. I'm looking to use materials I have on hand and just add the motor without having to double up batteries or buy new ones. So what's the fastest? Sorry to limit my question, but people on endless sphere go off in so many different directions that the original question often gets lost. Thanks.
kriskros said:bafangs have been run at 72volt 20 amp.... try holmes hobbies.... laced motor $300...he also has puma motors
Whiplash said:Hey guys, I see a lot of talk about the plastic gears, and I thought, why not take a page out of the 700R4 automatic transmission beef up book and replace the three sun gears with 4 or 5 smaller ones? The teeth seem to be the weak link and the way these planetary gear systems work, is the more planets you have the more the load is distributed over all the gears thus limiting the force applied to each tooth and making the assembly MUCH stronger! The transmission I am talking about, with added planet gears in the drive can be made more than 100% stronger by doing this, it would seem quite easy to do in this instance! I can't believe nobody has tried this?? JUST AN IDEA!! One of these babys with some good volts/amps would seem like a GREAT alternative for the slower off road mountain biking I like to do!
-Whip
