nlhaines
DanGT86 said:nlhaines said:Well if I screw up the BMS I'll just get myself a good 2 or 4 channel RC Charger. What do you do for LVC? Does the yescom kit handle that or do you have to add something?
If you do end up running without a BMS, get some Lipo alarms to handle the cell level LV warning. They are cheap and loud so you know when there is a problem. Lipo is most dangerous when its over charged or over discharged. The manufacturing tolerances are pretty bad on these packs so having bad cells in the bunch is common. Controllers do LVC for the whole pack total but they are blind to the individual cell voltages. If one cell fails and is about to explode but the rest are fine you can still be above the LVC at the controller. Cell level monitoring through BMS or at least warning alarms is an absolute necessity with LiPo in my opinion.
I learned more about batteries in just a few hours watching my RC balance charger than I learned from all of my reading online. A balance charger is a good thing to have around anyway. You can cycle your packs and make sure they all behave the same way before you hook them up to the BMS.
As far as paralleling the balance leads without checking them, that is a bad idea! There are varying opinions about how much difference you can have between cells when you parallel but I wont do it if they are off by more than .05v. High output batteries like these will try to balance instantaneously through those small gauge wires. I'm probably more careful/paranoid than most but its just not worth risking burnt fingers or the entire house. You can form your own opinion about how much imbalance you are comfortable paralleling but at least measure so you can base that opinion on something!
I'm not trying to talk you out of what you have already bought but keep in mind that these packs are dangerous and make sure the girlfriend understands that before you let her out of your sight with the bike. Might be easier said than done but maybe she should help you hook up the pack and the BMS so she has an understanding of how it works. You could always pick up a turn-key pack from ping or em3 that is as easy to charge as a cell phone. Then keep the Lipos for your own personal hotrod bike.
I should update the thread title, because my girlfriend is no longer convinced she needs an e-bike commuter. I'm doing a personal build now, and I'm sure she will eventually want one (if I can make it look pretty).
When I do get to building hers I'm just going to get her a safe, easy lifepo4 pack.
