You know you have a good weld when the tab leave parts of itself behind... You know your power is too high when your electrodes leave parts of themselves behind... probably unavoidable with those tabs and copper electrodes.
I have had miserable luck with tungsten electrodes. Lots of POW! and the tip blows off. I have some 3/16" moly rod coming. BTW, be careful grinding/cutting moly. It's a bit on the nasty side. Work outside, use a good nose condom...
Where did you get those tabs? They look like the ones in the Sunstone video.
With that design of tab you want to weld with the electrodes on the dimples (aka weldments). The split in the tab forces the current to flow in the tab, between the weldments.
