are your hips or knees wider than comfortably pedal on it now?
is spreading your hips/knees out wider while pedalling uncomfortable for you, for the length of time youd be pedalling for a ride?
if the former is true, then wider might be a good idea.
if the latter is true, then wider might be a bad idea. (and long term may damage your ankle/knee/leg/hip depending on the severity)
secondarily, if the triple you want to put on there will hit teh chainstay if the bb is the same, then you need a longer bb on that side to fix the problem. doing that will push your right leg out farther than your left, so that may be uncomfortable, too. (and long term may damage your ankle/knee/leg/hip) you can even that out by using a bb shaft that is longer on both ends so the pedals are at the same point on each side.
if the triple will fit without hitting, you don't need to change the bb length.
remember also that you would only be changing the width of the shaft and possibly cranks/pedals, you don't want to get a bb that itself is longer between it's bearings/mounts, or it won't fit into the bb shell on the bike. meaning, if it's a 68mm bb shell, you still have to get a 68mm bb, even if you get one with a longer bb shaft.
