Hi all,
I have a charger for my 13S battery which is not cutting the voltage when it reaches the low current at the end of the charge. It just have green LED which turns on when the current is about 150 mA. But it never cut the voltage. My BMS is like this one: https://enerprof.de/en/accessories-components/bms-pcm/13s/756/bms-13s-20a-for-li-ion-batteries-48v-in-reention-case?c=153
I saw that even Grin's smart charger never cut off the voltage. It just shows you the battery is charged by detecting the low current but the voltage is not stopped. As far as I understand this is because of the balancing as it might read very low current but still needs some topping. I know that keeping the battery connected forever to the charger especially on 4.2V/cell is not good for the cells. Does it means the BMS will cut off the charging when the voltage on all groups reaches 4.2V ? Then there is no problem the charger to provide the voltage forever...?
