nice idea here i like it.....i wish there were more threads like this on this things......
the people above mentioned solar powered charging e bike thread....
gensun charge controller or bioenno charge controller.....
maybe 40 to 60 watts of panel over bike rack.....24 volt amazon panels or string 12 volt panels etc....
also check out a thread called wood stove for bike.....
gasification system- sounds nice. nothing commercially viable. but this does make the most sense because you could use any biomass....sticks,garbage,zombie arms...etc.. auxillary heat could be used for cooking boiling water. now this will generate alot of heat.so be careful.....
commercially viable
http://americanpowerinc.com/DC%20Gen.htm.
so for like a grand you coould get a 24 48 or 36 volt charging gas enggine to charge a bike battery...must make sure your bike battery can receive charge and discharge at same time..
or run it through your charge controller...bike load goes on output load and dc charger primarly spenbt on bike motor while driving and a little charging...
however the dc charger gas one is like a grand has 9 horse power enginge...probably weighs 100 pounds...
solar panels 24 volt battery 20ah battery lets say....480 watt hours....solar panel 40 watts... let say you get half that 20 watts...lets say you lose 10 percent for charge controller and battery inefficiency or rainy day etc.....so 18 watts of power per hour into 480 would like 25 hours....roughly....
12 hours sunny days....
aleko makes solar panels for garage door opener and street lamps...they are bike size and relativly affordable but 60 watt 24 volt panel 70 bucks but weighs in at 20 pounds...this is doable but still means full day of arizona middle of july sun. bioneo charge controller or genasun charge controller....they are one of the few that i have seen online and actually have a call center where you can ask them questions. oh and chargelifepo4 battery.....they do make custom voltatges too ie 36 volt...
bieono power is more affordable but is pmw charging(sorry they released mppt charger last month) and genasun is mppt and buckboost mppt style....
the above poster probably mentioned the most important obstacle to charging a bike during a zombie appocalse....when SHTF time.... some one will probably kill you for your bike. it sounds like thats almost already happening in larger cities in america today.
so if were are theorizing here....
you need mirrors so you can see all your surroundings..you will need amazon/ebay motion alarms..smoke alarms activated by motion not smoke..you need to mount some sort of gun pistol to your handle barse both front and back. prefarably have them able to be taken off,,,prefarably by you....some sort of mechannism to fire while driving...also you will need some sort of gun strap on you so you can start firing...you know a judge taurus with 410 shot gun rounds on front and back would be cool.......but i am assuming something like a 22long rifle with 64 plus round clips would be more realistic and you carry the judge as an auxiallry weapon in replacement of your water bottle and maybe some short stock sks style pistol/rifle strapped around your chest. keep in mind that you must be able to carry all your weapons on you if you get off that bike. don't leave them on there....
also motion detectors demountable on bike to surround a permitter around bike either pointing toward bike if you are away from bike...or pointing outward if you are camping out...better to drive off and lose a motion sensor than have your brains eaten by a zombie......enjoy
