Hmm, yes/no? ^^^ :wink:
_____________________
From earlier posts of dan/arlo/luke:
We just need to be careful not to credit the band-aid as scientific evidence.
I agree with this, and that whole post.
Nutspecial. You are failing to realize. . . .
Yes I am.
The motor current is what determines the torque which is also the acceleration.
This is true. With a STRONG relation to human power, ICE, or hamsters in a wheel. 'all eletrons man.
. . . 1000lbs heavier and has 40 less hp.
Yes
relist the power figures at 532hp . . . . 200hp less
Yes, motors are rated combined @ 692, but
*battery limited* to 532
So 1000lb heavier and 200hp underpower, the S technically performs even more admirably vs mclaren, though it will be perhaps harder to improve perfomance competitive to mclaren in a balanced manner. Perhaps we could agree that 'battery= drastically weak link in E' already, and we'll need a fair amount more I assume.
So within reasonable comparable cost and weight, make the car compete as best with mclaren as possilble. Assuming the drags were after any limiting (active limiting or just specs 40% off or confused), we have 532hp and 1000+lbs doing fairly well in competition as seen in the drag.
How much MORE do we need to gain maximum shaft output of motors, and how much difference will it make in weight, cost, and performance vs mclaren? Will motors and controllers need upgraded? Just how identical could they become?
I don't even care if it can't 'beat' mclaren, what is acheived is the most comparable and competing ev vs mclaren. *cont below
So for this argument to define a cutoff in gearing benefit from hamster power to EV (or presently beyond),
In vehicles such as cars, trucks, and bikes, variable gearing will find decreased benefit as operational/conditional range/intensity of demands decrease, and/or power level and/or power efficiency increases
^ my observation baseline you can help refine if you like. Hopefully it's a solid start before further arguing definition of specific values.
notice as the speed increases the current from the battery increases
Yeeess. . . . for a single speed. . . . how does that help your argument?
Since there seems to be confusion on the topic, model S does spin it's tires until the speed it hits it's battery current limit.
Right, it rotates it's tires until current limit. . . . and even after letting off. Saw alot of rotation going into speed in insane mode, but the tires hooked up all the way. Was there something I missed?
Ultimately the EV powertrain's roll is to convert stored electro-chemical potential energy into a tractive effort.
Yes, basic statement. In fact 'electro chemical' could perhaps be broken down further? *Perhaps there are similarities to human and animal, and even ice.
The parts of the drivetrain that accomplish this is the copper and iron and magnets. The more copper you have, the less resistive loss for the conversion to occur. The more iron you have, the lower the specific flux density and lower rate of hysteresis and lower eddy potential.
Yes. . .
This is why big motors going slow have the potential to be most efficient, as well as make the conversion from the energy stored in your pack to your intended tractive force for the application with no further additions of losses or parasitic weight and moving parts to fail
Yes. . .
All perfectly accurate afaict, and good valid info, but my dumbass fails to see technical connection or any explanation to why in EV
All a transmission can add to that is weight and loss.
*cont- so take that best competing version of a 1spd S and copy it, adding then (at least) the 2nd spd. Could that help with any highly disproportional weakpoints remaining to mclaren, giving a more well rounded package in performance, cost, weight, handling, etc?
Then design and run custom 1spd vs custom 2spd comparing the above 4 criteria, and also comparing and considering the potential between the 2 ev's of trading some 'efficiency' for better weight, cost, range. . . and even some 'greenness' when trading steel vs lithium and/or copper.
