LockH
1 PW
^^ Watt HE says. Plus, I vote for electric bikes as travels seen as entertainment.
wturber said:I try to look at things that persist through history as a way to figure out those things that don't (and won't) change significantly.
John in CR said:vagosofron said:Correct me if I'm wrong, but isn't petrol necessary for electricity production? I mean, EVs are not 100% green if you look at the big picture. Despite that, I'm building my own though...billvon said:I think it's a pretty significant improvement in terms of energy and resource usage, but it's not a complete solution - just another step along the path to "better."MadRhino said:An electric car is not much greener than a combustion car. Unless it is half the weight and size, it is not a significative improvement.
Here in Costa Rica last year's electric production reached almost 100% from renewable sources...geothermal, wind, solar, and mostly hydro. The gas turbine backup system gets fired up only very rarely. Where electricity is produced by burning something the process is significantly more efficient and clean than burning it in a car, but you're correct in that nothing is 100% green, not even walking or pedaling a bike since powered by food is one of the most inefficient, costly, and pollution creating power source. Ebikes OTOH are the most efficient form of land transportation devised by man, and whether I charge mine from a wall socket or using my solar panels, they're about as green as it gets. Plus until we can move around by personal multi-rotor aircraft, they're the most fun and most time efficient and economical means of transport.
Why not use your own solar panels to charge your battery? Just one 4' x 2' solar panel can easily charge a 48v 20ah battery in a day (generates up to 200w per hour). Get a few panels and you can power your home lighting and maybe even the movie projector toovagosofron said:Correct me if I'm wrong, but isn't petrol necessary for electricity production? I mean, EVs are not 100% green if you look at the big picture. Despite that, I'm building my own though...
John and Cecil said:Why not use your own solar panels to charge your battery? Just one 4' x 2' solar panel can easily charge a 48v 20ah battery in a day (generates up to 200w per hour). Get a few panels and you can power your home lighting and maybe even the movie projector toovagosofron said:Correct me if I'm wrong, but isn't petrol necessary for electricity production? I mean, EVs are not 100% green if you look at the big picture. Despite that, I'm building my own though...
Even if the power was not 100% green we are now averaging over 1000 miles per gallon (based on electricity/gas cost)!
DRMousseau said:Most notable was cost as a barrier to ownership!!! Especially the significant difference between those <60ys, and those >60,...
That's what we do. Although usually to be good "grid citizens" we generate power during the day (when the grid needs it) and charge at midnight (when the grid has surplus.)John and Cecil said:Why not use your own solar panels to charge your battery? Just one 4' x 2' solar panel can easily charge a 48v 20ah battery in a day (generates up to 200w per hour). Get a few panels and you can power your home lighting and maybe even the movie projector too
For a much lower cost (and lower hassle) way to do that consider a "net zero export" grid tie system. It is a system that will never export power to the grid - but will power your home 100% when the sun is available to do so. By moving all your loads to daytime (washing clothing, cooking, AC etc) you pay almost nothing for power.John and Cecil said:I was considering cutting the cord to the power company completely. I am not even sure if they allow you to upload power to the grid in Italy.
LockH said:So V.Sorry to read that such "cheap" transportation (?) is a "barrier" to some.
billvon said:Batteries sound great, but they end up as the #1 cost in any system. To use lead acid for full time power you have to cycle them fairly hard, so you either use a few batteries and replace them once a year or use a lot of batteries and replace them every five years. And lead acid batteries generate hydrogen, and need water, and you end up with little acid holes in all your clothing . . . .
Li-ion or LiFePO4 are much better of course but also much more pricey.
Over the long term, the grid is a much cheaper "battery" than a battery.
Petrol as in oil? Not here. The only place the US uses oil for electrical power to any degree is Hawaii because that's the only fuel we can ship there.vagosofron said:Correct me if I'm wrong, but isn't petrol necessary for electricity production?
Right - they are just a lot greener than IC cars. And as time goes on, and more of the grid switches to renewables, they will get even greener.I mean, EVs are not 100% green if you look at the big picture.
If you get very good batteries (Rolls and the like) AND you treat them well AND you have a lot of experience in the care and feeding of lead-acids that's a reasonable expectationDRMousseau said:Even the basic flooded wet-cell batteries have benefited from recent technologies, and are far better than in their former basis of the not so distant past. Of course glass-mats and gels can hardly be called an advancement given their "disposable" nature of a relatively short life due to consumers need for "maintenance-free". They ARE safer in applications needing such safety against constant upright use. Flooded lead/acid DO require some personal maintenance and attention to last longer the gels and mats, and I expect fully 7yrs+ of regular use from my banks.
But for lead acid nothing has really changed. Still three phase charging, still equalize charging for balancing, same temperature compensation that has been around for decades. One of the reasons lead-acid is fairly mature is that they were the mainstay of telecom and data center backup systems since the 1930s - so people have a lot of experience with what works and what doesn't.Of course it helps to have good charging and monitoring technology that was unavailable to me years ago.
Yep, lead acids are definitely cheaper in terms of up front cost.Lithium an advantage??? Ya,... it is. Much lighter, more compact, somewhat safer in application, greater power density and efficiency,... and of course costly. Given life expectancy and application purpose,.... I'll stick with flooded cell batteries for my home, and lithium for my e-bike and other things. Been fading away my use of alkaline and other disposables,... not so much for cost, but for budget!
Well, for backup you really can't beat a generator. But if an off-grid system works for you, great.Of course I Iuv the grid, but my systems are such that I hardly notice when the grids down due to local weather or whatever. I actually have installed special visual indicators to display loss of grid power, otherwise I'd hardly noticed. Seems odd that I'd be the only one in dark local neighborhoods with lights and power at such times. Nice having backups.
DRMousseau said:Some??? Seemed pretty significant to 70-80% of the large number of respondents.LockH said:So V.Sorry to read that such "cheap" transportation (?) is a "barrier" to some.
wturber said:financial sense
John and Cecil said:wturber said:financial sense
That term is where we differ in opinion. I would rather spend more and take the money away from the big corporations. The corporations are the problem, and they funnel money to the politicians to allow them to abuse the planet. A good example would be big pharma. Republican senators received 92k on average in 2016 from big pharma, and the average dem senator received 61k. There are drugs in our drinking water and yet the water is not tested for them (only by the AP). The system is completely broken.
John in CR said:I go even further, everything BIG is the problem, whether it's big oil, big government, big pharma, big utilities, big banks, big insurance, big healthcare, military-industrial complex, etc. With near zero exceptions they operate in a morally corrupt manner and take actions contrary to the common good. With the laws allowing them to collude more and more each year they've become like one evil entity I refer to as BIG. BIG is the world's biggest problem, and I'm with you in that I'll pay extra to avoid giving money to BIG.
... and:Inside Higher Ed is a media company and online publication that provides news, opinion, resources, events and jobs focused on college and university topics.
Inside Higher Ed's content regularly appears in other publications such as Slate and Business Insider. Inside Higher Ed has been recognized by The Association for the Study of Higher Education.
This weekend my wife and I took our college-age daughters to the New York International Auto Show. In truth, we had not planned to attend the giant car extravaganza held annually at the Javits Center. We had planned a weekend in Manhattan as a spring break getaway, and ended up at the car show largely by happenstance.
There is some degree of irony in my attendance at any auto show. Our oldest drove away with our second car at the start of her sophomore year. My wife drives our family (and only) car to work. Most days, I don’t drive anything bigger than an electric bicycle.
Cars are expensive and dangerous. Nowhere at the NY International Auto Show was there any mention of the approximately 40,000 U.S. vehicle deaths in 2017.
Many of us don’t want cars, but transportation.
