cycle analyst v3 problem
ROG130
united kingdom
hi all i am having a problem with my cycle analyst v3 displaying wrong battery volts
my setup is
bmc v4t hub motor
bmc 50a controller the black type
The batteries are 58.8v max, 14S 10Ah and are made up of 14 no 9959156-10c li-ion pouch cells.
i added to the c/a a separate speedo cable and spoke magnet as it was the CA3-DP and no good with my bmc motor
the problem is no matter what battery config i use volt or number of cells you add in setup
on main display it keeps saying 77v and the battery meter keeps saying full battery
even when its flat
i have tried to find the controller shunt size but have not had much luck
i have played with the shunt settings in the c/a but volts did not change
and i have updated the firmware as of today 23rd aug 2014
any help will be good
or if you had the same problem with the same setup and fixed it please
let me know how thanks roger :mrgreen:
thanks for info amberwolf
i will find another power supply and test it
will have to be tomorrow as helping my brother fix his car today
will post up what the results are
and find out what to do next
thanks for the :D help roger
hi has anybody got the cycle analyst version 3 parameters
for the BMC V4 rear hub motor
18 FET BLACK BMC 50A Controller
14S 10Ah 58.8v lithium polymer 150A max discharge battery pack
bike running 26" wheels
just need to get the right settings for the
CA3-DPS
plus help with setting up a 3 speed switch for this setup
CA3-DPS
http://endless-sphere.com/forums/viewtopic.php?f=4&t=37964&start=225#p571345
Have you read the manual?
yes i have and had a go at setting it up but
still having problems with showing right volts and battery gauge level ect
so looking to find somebody with same setup and try there settings
to see where i am going wrong :x
