ROG130
hi all i am having a problem with my cycle analyst v3 displaying wrong battery volts
my setup is
bmc v4t hub motor
bmc 50a controller the black type
The batteries are 58.8v max, 14S 10Ah and are made up of 14 no 9959156-10c li-ion pouch cells.
i added to the c/a a separate speedo cable and spoke magnet as it was the CA3-DP and no good with my bmc motor
the problem is no matter what battery config i use volt or number of cells you add in setup
on main display it keeps saying 77v and the battery meter keeps saying full battery
even when its flat
i have tried to find the controller shunt size but have not had much luck
i have played with the shunt settings in the c/a but volts did not change
and i have updated the firmware as of today 23rd aug 2014
any help will be good
or if you had the same problem with the same setup and fixed it please
let me know how thanks roger
my setup is
bmc v4t hub motor
even when its flat
