Toshi said:oatnet/JD:
... resize the image in your signature. It is so large as to be disrespectful to the other users of this forum, and quite a few users have asked you to do this before.cleaned up suggested oatnet
Toshi said:Will surface rust hurt the arms or fork? I'm all for making the bike uglier and more unattractive. It does stay parked outside the hospital for 30+ hours after all...D-Man said:Dude, you should paint the torque arms! Paint is cheap! After all that work!
oatnet said:At any rate, the easiest thing to do would be to add me to your kill file - its not like you inspired me to offer my help again. If that doesn't suit you and you don't like this forum's policies, I suggest you work with the mods to change them.
-JD
oatnet said:Toshi said:oatnet/JD:
I have actually received FAR more compliments/inquirys about my little 64kb sig than criticisms (3, including yours), and its placement is within the policies established for this forum.
After years of experience with interesting sigs on other forums, I personally would like to see more and larger pictures of people's creations in their sigs. I would be exposed to a broader range of creations than I have time to find on my own, and when someone does something new/different I am likely to notice it earlier. It adds a social element, revealing more about the personality of the forum member than just cold text and miniature avatar. This is why I have not caved to suit the minority of complainers.
-JD
Toshi said:11 PM update:
pesky little bugger chiseled out after heating epoxy with the soldering iron:
new sensor in place after reaming out the hole a bit with an awl:
new sensor bathed in epoxy. 90 second curing is too fast! last time i buy that stuff. note dabs of electrical tape covering Worlds Ugliest Solder Joints (TM). it's probably been a dozen years since i last soldered in earnest.
finally, a high tech mounting solution for the desiccant bags. the stator is stationary (fixed to the axle), as it's the hub shell that rotates about it, so i figured this mounting setup might do.
11 PM update:
[img]http://toshiclark.com/images/biking/bikes%20and%20parts/hall%20sensor%20fun%20-%20june%2022,%202008/Images/IMG_5053.jpg
if this all doesn't work and the Hall is still bad then i'm just going to order a pedal-first (vs. immediate start) controller and sell my current one. pedal-first controllers don't rely on Hall sensors so this problem would be guaranteed to not recur.
Correct, the side plates have no seal or gasket.Mark_A_W said:There's no lip seal on the side plates? Just outside the main bearings?
