beto_pty
Actually it was reset and accelerated to verifiy remote control bind... Id say Wp is definitly 250w on its own...made_in_the_alps_legacy said:Thxs bto_pty, runs very nicely.
could not rely on the Wp reading since the test was started without resetting the wattmeter,
Also leads to conclusions regarding the maximum wattage that a motor should deliver...at 45-50 amps is probably not continiuus..
If we look at sebastians graph from his post http://endless-sphere.com/forums/viewtopic.php?f=35&t=59576
http://endless-sphere.com/forums/download/file.php?id=136531666yeti666 said:wow 90 amps, that's a lot. My measurement values are a lot more conservative, (singe drive 6374-170 motor+ 6s lipo) see my datalog :
we see that tough he maxed at 38 amps, his average was under 4 amps...
From aprox 300 data points, if we were to eliminate the top 15 (5% of the points) we would have a max amp rating of only 14 ams. Turning this into percentages. The average wattage is 10% of the max. 95% of the wattages were under 40% of the max... I tend toa gree fully with this info.
Overkill?
150 amp controller and 90amp connectors to pull somewhere around 35 amps continious in my case
2400 watt motor to pull probably around 800 continiuos...
Id like to know if anyone has burned up their ESC or motor for non Hobbyking-quality related issues?
