CamLight
Thanks Doc!Doctorbass said:The water measured waterflow was: 235ml per minutes
The ambiant temp of the water at input was 20.9 degree C
The water at the output of the heat sink tube was 24.3 degree C
The resistor temperature close to the heat sink was at 34.4 degree Celsius
The dissipated power was exactly 50Watts
CAMLIGHT HERE ARE THE DATA YOU ASKED FOR:
34.4 degree C at the resistor.. the closer as i was able to put that sensor and firmly pressed against the resistor and aluminum heat sink.
with 235ml per minutes
Doc
I'll use your numbers...
Assuming 20.9C ambient, 34.4C heat sink temp, and 50W power, we get the following:
34.4C - 20.9C = 13.5C temperature rise.
13.5C / 50W = 0.27C/W heat-sink-to-ambient thermal resistance for the setup you described.
Using tostino's numbers (adjust as necessary for whatever power dissipation levels are finally determined to be the proper numbers to use)...
- 36 FETs with 311W to be dissipated.
- The better Sil-Pad's at high pressure (over 100PSI for the TO-220 mounting pressure) = 1.75C/W case-to-sink thermal resistance. This can shoot up to over 6.0C/W for the lousier performing pads at lower pressure!!!!!
- IRFB4110 junction-to-sink thermal resistance - 1.11C/W.
Soooooo, here goes...
- Total junction-to-sink thermal resistance for each FET = 1.11C/W + 1.75C/W = 2.86C/W.
- Equivalent junction-to-sink thermal resistance for 36 FETs = 2.86C/W / 36 FETs = 0.0794C/W.
- Junction-to-ambient thermal resistance for 36 FETs on that bar with the above-mentioned cooling setup = 0.0794C/W + 0.27C/W = 0.349C/W
- Temperature rise for the FETs = 311W * 0.349 = approximately 109C junction temperature rise, above ambient, for the FETs.
This assumes.....
- All 36 FETs are on that one bar.
- Each FET is dissipating the same amount of power. This ain't going to happen. But, you can recalculate as necessary if the power levels for any individual FET is higher or lower (e.g., for high-side and low-side FETs).
- The water stays at the same temperature all the way down the bar. This ain't going to happen either. Let's assume that it goes up 10C at full power (maybe?), then the FETs operating where the water exits the block will be operating 10C higher than the ones near to where the water enters the block.
Assuming your ambient (water) temperature is 21C - 31C over the length of the block, your FETs will be operating at 130C - 140C if dissipating 311W.
That's not a problem at room temperature but at higher ambient (water) temperatures you'll start bumping up against the maximum recommended junction temperature for reliable, long term operation, 145C. If you want to exceed that temperature, you've got another 30C before you reach the abs. max of 175C.
