AussieJester
1 TW
@j3tch1u simply brilliant build mate, definitely set the bar high for e-MTB builds...
Outstanding...
KiM
Outstanding...
KiM
mucho gracias luke. frank will get his leckky power cherry popped on Dogati tomorrow
ghettoracer said:mucho gracias luke. frank will get his leckky power cherry popped on Dogati tomorrow
didn't you say the torque murdered the clutch bearing?
i'm game for a quick china trip. lets get luke's itinerary and see.
recumpence said:Be careful, the HV160 tends to blow with too much EMF feed from the motor with throttle off.
Matt
j3tch1u said:recumpence said:Be careful, the HV160 tends to blow with too much EMF feed from the motor with throttle off.
Matt
do you think it could blow from just the pedalling input? the rear hub freewheels so it won't be driving the motor when coasting.
Jeremy Harris said:Any chance you could put the pictures back up, please?
(I just get a message like this when I try and view any of them:
"Information
The selected attachment does not exist anymore.
The file ./../files/7956_6bb93bf91e3aab6b04dc98729fcfb969 does not exist." )
liveforphysics said:Also, with your cap placement and wiring, its really really important you keep the wire length between the cap module and the controller PCB as short as physically possible to have it help. This will help the controller have it's best chance at life. If you want some of the best low ESR caps (that are in a small form-factor) that I was able to find in all my cap testing with my ESR meter, I can send a box to Frank or you for free if you want to PM me your address.
rodgah said:i love the bike j3tch1u it is an absolute masterpiece.
regarding the gearing......have you got the castle data link cable? I am curious to know what the temperatures got like riding around. I think I read that yours is a 5t 3220 which is the same as what I had on my dual drive. When I tried just one motor (in an attempt to tame the bike down a little) I did a few short take offs, say 3 and around 500 meters of total run time and the temperature of the hv160 went through the roof! and thats with it geared for only 80km/h. I believe some of the heat or maybe alot was due to not being able to reduce the gear ratio as it was a single speed. So what is your no load speed in 1st gear?
Cheers
ghettoracer said:looks like you've been berry berry productive. =) sweet. this sat should be sun shine again. i hope we get some real sun this time!! Whiplash: the weather is uncooperative lately and it's gloomy and wet in taipei mostly. dogati isn't quite water proof so the filming will have to wait until better weather which is hopefully this coming weekend. then ben has promised his pals/gals to wear some leather tights for the video shoot. haha j/k.
Whiplash said:WELL? did it run OK?? WE NEED TO KNOW!!!! LOL!
