Whoa. Whoa.
This must be the welfare generation or something. You guys are nuts.
REdiculous said:
A 70lb limit means it's a race for people that can afford decent batteries and everyone else can stay away.
swbluto said:
The 70 lb. weight limit is NO FAIR! That gives RC-motors/Outrunners a really unfair advantage since powerful hubbies would have to pack much less battery.
REdiculous said:
I think a slightly higher weight limit (100lbs? I dunno) would be nice for folks stuck on SLAs. later
REdiculous said:
I agree, 6kw is more normal here but I think we should agree to disagree on the power needed for a fun race...
A 2HP pocket bike can do 35mph w/ a 200lb rider pretty easy so I see no reason for 8HP on a bicycle. That's not an ebike race, it's a contest to see who who has the biggest balls and who can spend the most money. :lol:
WTF world do you guy's live in?
It's called a a RACE. It's not called a balanced equality fairness group touring session.
Race means, you use every inch of your brain, and whatever resources you can scrape together to put together your best shot at winning.
Racing is about racking your brain to design and come up with any possible unique advantages you can build/create/train to have, then trying to leverage rules, and sneaking anything possible through tech inspection (in our case, just a scale to weigh), and comming up with anything you can think of to give yourself an advantage.
Hell, I run in a class where every other car there has it's own truck and trailer and crew for support, loads of sponsors, and often as much money in useless asthetics than I have budgeted to race for the season. I gotta drive to events on the same engine I'm gona race on, with the inside of the car loaded up with tools and slicks etc. I don't have the budget to buy the $25,000usd G-force gearboxes they run, and have rebuilt every 2-3 events. I don't have 2 spare engines waiting in the trailer, each pre-broken-in on the dyno and with it's own programmed ECU waiting in the event of engine failure.
I build my own race stuff, almost entirely from scratch, sacrifice/save to buy the few parts I can't make (like F'ing gearsets... DAMN i hate buying gearsets!!!) and use my head and any tools I've got to try to match the performance of the big budgeted teams I run against, and it WORKS!
If you want to make a competitive entry bad enough, it really doesn't matter your budget, you can make it work if you dedicate, use your brain to it's fullest, and sacrifice.
Hell, even if you had ZERO e-bike parts to begin with, it's 1 year time to put away some resources to make it happen. Let's say you save up $5 per day between now and the time of the event to put towards making your bike. That's $1,825 that you've got. Lodging and food and local transporation is on me, Seattle is a $250-350 plane ticket from about anywhere, shipping the bike about $100. That leaves you with ~$1,400 budget to build the bike, which is plenty to make a top level racing bike if you spend it wisely. Hell, if you average 30mph for a 12.5mile course, that's 25mins of racing. With just 1kw-hr of LiPo (about $500), you could average 2400watts for the whole 25mins (on a tight track with half the time coasting or brakeing, that's like 4800w anytime you want to accelerate!) Or average over 10kw for the entire hill-climb on the same battery! Or, from the research I've done, if you're willing to dedicate the loss of some life-cycles on the pack, charge the cells up to 4.4v/cell and get an extra 25% energy density for the 12.5mile race. Then you could either choose to buy less LiPo and have a lighter pack and lower budget, or setup to run a higher average power etc. Pack-heating before the race would also be another economical way to secure some performance advantages.
Also, it's racing, not commuting. This means no BMS stuff needed, no worries about cells getting out of balance, power monitoring, or chargers ( I will have plenty of premium chargers and power supplies available for anyone to rapid-charge).
If you want to make an effort to race, then you gotta bite the bullet and do what it takes to trim your budget by ~$5 a day (or however much you will need) to make racing possible if you're dedicated enough to want to race.
That is, and always has been the nature of the sport of racing.
