elliothaughin
- Joined
- Feb 28, 2011
- Messages
- 38
So, I've spent the last 8 hours straight researching batteries.
My conclusions so-far.
1. I'm scared of Lipo, however I look at it, I just know I'm the kind of guy you'll see on the news in bits after charging his lipos in the shower whilst smoking.
2. A123s look very cool, but I'd need someone to build the pack for me with BMS/charging ready to 'plug and play'.
3. Headways.... why didn't I see these before!
So, Headways in a 16S1P arrangement give you 48V at 16aH, which is brilliant! Plus, I could probably build a pack of these myself since they're put together with a screw fitting.
I could pick up 16 of them for $511.20. At 40mm wide, I could build a pack that's just 1 unit-wide, which would fit nicely in the frame.
The only 'complicated' part would be the BMS, but I could always find someone local to the bay area with a soldering iron and some technical skill to wire on a Goodrum/Fechter BMS (They look fantastic).
It seems a bit too good to be true really, the only thing I can't work out is if the 'C' rating for these is good enough to run an eBike with the 'ooomph' I need.
There's people using these batteries to power cars though.
Headway-headquarters also sell a 16S1P headway pack based on the same cells, and quote these as figures for power on the pack overall:
From the sounds of that 750W motor would be lovely! What do you guys think? Would headway be a good option for a noob to get started without killing myself, or have I missed something and these just won't work for what I want?
Thank you!
Headway 40160S(16AH)
Normal capacity - 16000mAh
Normal voltage - 3.2V
Inter impedance - <8m¿
Maximum Charge Current - 5C(80A)
Maximum Charge Voltage - 3.65±0.05V
Maximum continuous Discharge Current - 10C(160A)
Discharge stop voltage - 2.0V
Diameter - 40±1mm
Height - 160±1mm
Weight - Approx. 500g
The largest Headway cell that we carry continues to have those great Headway C ratings! 10C continuous to 15C max (160A continuous to 240A max)
16 cell 48V16Ah Battery Pack
Max Motor Watt Capabilites - 2000W
Recommended Motor Wattage - 750W~1100W
Voltage - 48V
Capacity - 16Ah
Recommended Charge Voltage - 58.4V
Recommended Charging Current - <20A
Recommended Max Discharge - 48A
Max Discharge Current Available - 160A
Discharge Cut-off Protection- 60A
Thank you!
